Latest news: ---- BMW BEV & PHEV Tool Project ---- BMW Easy Connect 2 v1.9 TOOL ---- Hitachi 220-6 Workshop Manual ---- Injector Statics Dynamics Calculator Tool ---- WinOLS Organizer Automatic Tool ---- Bosch MD1CS TPROT Bypass Tool ---- BMW EDC16 EEPROM TOOL ---- Deutz-Fahr Tractors Factory Service Workshop Manuals ---- Ksuite 2.25 Clones Kess 5.017 Ktag 7.020 ---- ODIS Service 7.2.1 Multilang VAS5054A 6154 Passthru J2534 Win10 ---- HITACHI ALLINONE TOOL 3.9.0.0 MPDR 3.22 MEGA ---- VAG BMW MB OPEL PEUGEOT EDC17 FILES MEGA ---- Volvo Tech Tool Devtool License Editor Keygen Full ---- Fiat ecu map ---- SVEdit v1.1.38 ---- BMW E-SYS PSdZData Tool New Version Link MEGA ---- VEDIAMO PASSTHRU 5.1.1 + KG + PATCH ---- GM ECU FLASHER TOOL FIX ---- BMW CODING PACK FILES MEGA ---- iDecoder 4.5 No HWID Full ---- ECU Tuning Solutions 1.02 No HWID ---- VCDS HEX NET SUPPORT WIFI DOIP TOOL ---- BMW ETK Price 11.2026 ---- K-Suite Collection Professional Software Kess V2 K-TAG ---- GM GDS2 SOFTWARE + KEYGEN + PATCH ---- ECU Repair Guide Electronic Tool 2022 ---- BMW E-Sys 26.04.02 New Version MEGA ---- Best K-Suite Version For Kess 5.017 K-Tag 7.020 ---- Immo Doctor 2.1 + Multi Editor + DTC Off + Keygen ---- Subaru SSM3 Universal J2534 04.04 Patch Full ----
AlpinWeiss2k26 Online
BMW
Hi all,
Over the last months I've been developing a Windows tool for a job that keeps coming up on hybrid and electric BMWs: checking the high-voltage battery properly before buying, selling or repairing a car. I'm sharing it here because I think it can be useful to other workshops and independents.
What it is
HV Tool – a single .exe for Windows, no installation, works completely offline. You connect a standard ENET cable, ignition on, one click – it finds the gateway, reads the VIN and I-Level and detects the model by itself.
High-voltage battery (SME)
SoC, SoH, pack voltage, current, power, available energy
Every individual cell voltage and temperature, grouped by module exactly as the SME reports them
Cell imbalance – spread between highest and lowest cell (Δ) and standard deviation (σ), min/max per cell and module
Insulation resistance, contactor state, cooling, charge cycles
A plain verdict at the end: OK / attention / likely fault
Rest of the car
Fault memory of every control unit, with full descriptions – 378,449 fault codes from 1,355 control-unit variants built into the .exe
Confirmed faults counted first, network "event" faults kept separate as secondary
Clear one module or all faults with one click
Live engine data per engine type: boost, rail pressure, air mass, injector corrections per cylinder, full DPF/OPF set, VANOS, lambda, ignition – with graphs, alarms and CSV recording
12 V battery (BZE/IBS): SoH, capacity, quiescent current, deep discharges, internal resistance
CBS service: remaining km/days, due dates, reset per item
Mileage check: mileage stored in every module compared, with Secure Mileage tamper flags
Clean PDF report for the customer, no personal data in it
Coverage
129 models – BMW, MINI and Rolls-Royce, F/G series and the newest platforms including Neue Klasse (iX3 NA5, i3 NA0 with cell-to-pack layout), X5 G65, M5 G90/G99.
How it talks to the car
HSFZ over ENET, UDS services and each control unit's own data layout, so the values are the real ones read from the modules, not estimates.
There's also a built-in demo mode, so you can click through every screen without a car connected.
