Latest news: ---- Vediamo J2534 Switcher ---- Multiecuscan 5.3R1 + Keygen + Patch Full ---- BMW ISTA UPDATER GUI 1.4 NEW FILES ---- Delphi Skoda RCD310 Calculator ---- PCM Flasher New Version 1.2.1 TOOL ---- XENTRY Diagnosis PassThru OpenShell 37.8.2.1 [06.2025] FINAL ---- XENTRY OpenShell 26.3.4 FULL ---- XENTRY PassThru 26.3.4 FULL ---- GM Global Tis Full MEGA ---- TEBS Diagnostic Tool 2.6.12 FULL ---- JPro 2025v3 Install + Activator Full Work ---- PDF Machine Ultimate + Keygen ---- GDS2 Global Deliverables New Update Files + KG MEGA ---- CUMMINS CALTERM 5.16 + ECFG FILES COLLECTION ---- BMW ETK Price EURO 05.2026 ---- VIN To HEX Converting TOOL ---- IMMO SERVICE TOOL COLLECTION + KEYGEN FULL ---- Davinci DPF EGR Remover 1.0.35 Full Activated ---- GM BCM IPC ECM VIN TOOL ---- XProg 5.5.1 Software + Atmega Flash Full ---- CNH Service Manual Wiring Schematic Collection ---- Honda HDS 3.102.051 Diagnostic Tool Software ---- Renault Can Clip 232 File Mega ---- ODIS-S 23.0.1 + ODIS-E 17.0.1 + KEYGEN PATCH ---- Volvo XC60 - 2017 Wiring Diagram ---- JLR SDD v16X OFFLINE TOOL ---- J1939 Database Files Collection ---- JLR SDD + PATCH 167-168-169 FULL ---- Davinci DPF EGR Remover 1.0.34 Full Activated ---- EaseUS Partition Master 20.3.0 + Keygen Full ----
Tactrix Openport 2.0 Ediabas Konfigurator
0. First, install PassThru
1. Start -> BMW PassThru 2.1.0.0 -> PassThru Configuration
2. In the window that opens, select your Tantrix adapter, check the "V" field in the "K-line support for 115200 bps" item.
3. Go to the folder C:\Program Files (x86)\BMW AG\PassThru
4. Select and copy all the files in this folder.
5. Go to the folder C:\EDIABAS\Bin !!!MAKE A BACKUP BEFORE COPYING!!! and paste all the previously copied files from page 3.
6. Open Ediabas-Configurator. In the "Interface" window, select INTERFACE=STD PassThru and click "Apply
Thanks given by: wojkan , Admin , AUTOHEX , AUTOHEX
