Latest news: ---- Volvo Tech Tool PTT 1.12 + Keygen Full ---- xDecoder 14.0 Launcher Package Fix ---- HP Tuners 5.1.1.198 + VCM Keygen FULL ---- SM3 Scanmatik Alpha4 PCMflash ---- JLR SDD ENGINEERING CALCULATOR TOOL ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ---- Zenzefi Aftersales Certificate 23.11.2026 Full ---- Diagbox 7.57 Files Complete Full ---- Man Mantis 12.2025 Full Activated ---- Mercedes WIS ASRA Standalone 10.2021 Activated ---- DTS 9.02 Keygen Patch FULL ---- DTS Monaco 8.16.015 Keygen Patch FULL ---- FoxFlash Offline Loader For KTM 200 Complete ---- DTS Monaco Projects Files Collection FULL ---- Smart 453 0.9 Turbo 66kw - need stage1 file ME17 9.20 ---- WinOLS 4.7 Native Installer + Complete Guide ---- Iveco Easy 18.1 Trucks + Buses + Keygen + Instruction ---- VCDS LASTEST VERSION FILES MEGA ---- ECM Titanium 40.000 Drivers Chip Tuning Firmware Editor ---- UPA SOFTWARE + SCRIPTS COLLECTION FULL ---- Ecu Connections All Cars Tool ---- DTS Monaco 9.02 + Patch + Keygen + Projects Full ---- Easy Kill v2.0 Start-Stop Off Tool ---- iDecoder 4.5 Ultimate Automotive ECU Immo Solution ---- ECU Repair Guide 2022 TOOL ---- Challenger TerraGator 3244 Service manual ---- JPRO 2026 v1.1 WITH ACTIVATION FULL ----
Eaton Service Ranger 4.2 Error
Savior2064 Offline
I've installed service ranger 4.2 a few times on some of my computers successfully but this one computer that I'm trying to install it on for the past couple of days gives me an error that I need to connect to the internet to register the product.
Steps I've taken
1. Clean install of windows multiple times of versio 1607 and other version.
2. Made sure replaced files and installed database correctly with admin permissions
3. Used windows 7 to get serials
4. Installed it on another computer with out a problem
5. Ran the program and installed in windows 7 compatability mode.
6. Put links into host file to block
7. Disabled and enable internet while trying to activate.
8. Tried dozens of different serials
9. Made sure hash key was the windows 10 computer
Not sure what else I can do to get it to activate on this one computer or if I'm missing something.
Can some one please help me out or suggest something or if I'm missing an extra step.
Thank you in advance.
Thanks given by: Guay , sainface , smhdrms , Zebuboss , electrobtp
MizteriouzA Offline
Hey Friend,
I have heard of people running into problems when trying to install it on Microsoft Surface products and Panasonic Toughbook cf-33 and other tablet like computers not sure if that's the issue here but just throwing that out there!! Good luck Friend!!!
Thanks given by: kevine75 , kliszka , dabu , melih22 , oomitsme
Savior2064 Offline
(05-29-2025, 06:40 PM)MizteriouzA Wrote: Hey Friend,
No it's an Hp elitebook. I have another unit the same and am able to install it on that one.
Savior2064 Offline
Figured it out. Did a clean install with one of the first windows 10 version. I was even able to run the keygen on windows 10 with out a win7 computer.
Thanks given by: asd-ala , rafikzros , KrittanuC , smhdrms , kGADITSWE
jose Offline
(07-13-2025, 10:16 PM)Salvador2064 Wrote: Lo resolví. Hice una instalación limpia con una de las primeras versiones de Windows 10. Incluso pude ejecutar el keygen en Windows 10 sin una computadora con Windows 7.
HOW DID YOU SOLVE IT?
Thanks given by: cocot8 , Jerome
MizteriouzA Offline
Do a clean install of windows 10 but without updating any of it then install service ranger 4.2 run the keygen and confirm it works after service ranger is loading correctly you can update windows and it will still work friend.
Thanks given by: mat164406 , ninja4k , p3dru
