Latest news: ---- Toyota Corolla Apple CarPlay Android Auto New Update ---- Help with Jpro installation ---- Pre-installed ODIS 25.0.3 and ODIS Engineering 19 ---- Man Repair Manuals Wiring Schematics Mega ---- PCMflash Original Version Drivers J2534 Wiring FULL ---- ECU Pinouts Collection IMMO Wiring ECU Pictures ---- JCB ServiceMaster 25.1.0 Unlocked + Fix MEGA ---- Best K-Suite Kess K-tag Version Update ---- WinOLS 4.7 Latest Version Update ---- KESS K-SUITE 2.48 Latest Version Update ---- Hello From USA ---- ETKA 8.6 International English 01.06.2025 Virtualbox ---- Vediamo 5.1.1 + Activator Tactrix OpenPort 2.0 Full ---- Actros MP4 MP5 MANUALS ---- ZenZefi Certificates 23.11.2026 Full ---- Xentry Activation Working 2026 Windows 11 Full ---- Bosch ECU Database v0.3 Full ---- Bosch ECU Circuit Diagram EDC ---- DTS Monaco 9 Passthru Interface Configuration ---- Haynes Pro 2018 Virtual Box Full Mega ---- Komatsu manuals, anyone can share? ---- TOOL32 SERVICE HISTORY WITH EDIABAS EXTENSION ---- Introduktion ---- PCM Flash 1.20 Cleaned No Virus ---- PACCAR ESA COMPLETE + KEYGEN + SW FILES FULL ---- VCDS 25.3.2 + VIIPluslоader STM Arm ---- DTC Toyota Lexus Firmware Editor English ---- XENTRY 09.2026 FILES FULL ---- Immo Doctor v2.1.1 Full ---- How to Read an Electrical Schematic A Step by Step Guide ----
Cummins Inline 6 - Good truck diagnostics device with European Union quality
Cummins
It allows you to diagnose all vehicles with Cummins engines. Able to completely reprogram ECU - increase engine power and turn off urea. To upgrade the ECU, you need to use a Cummins inline 6 dealer device, no OEM-supporting adapters (for example, DPA 5 or Nexiq) can be used.
Suitable for adjusting the technical parameters of internal combustion engines from other manufacturers that support the RP1210 standard (Detroit DDL, Caterpillar ET, etc.).
Functions:
  • Vehicle system setup
  • Guided Diagnostics
  • Setting up control units
  • Read DTCs and Reset Errors
  • Coding and programming of electronic control units (ECU)
  • System calibration
  • Actuator Tests
  • and much more.
Equipment:
  • INLINE 6 data link adapter (P / N 2892093)
  • Protective cover for the INLINE 6 adapter (P / N 2892096)
  • Disk with software INLINE 6 (P / N 2892095)
  • DB25F / 3-pin / 2-pin / 2-pin cable (P / N 3165141)
  • DB25F / 3-pin / 3-pin cable (P / N 4819780)
  • USB cable (P / N 2892094)
  • Adapter J-1939 (P / N 3163597)
  • Extension J-1939 (P / N 3163096).
Price $559 (shipping included)
[Image: Cummins-Inline-6.jpg]
Need it? Write to me to discuss the details.
