Latest news: ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ---- Volvo Tech Tool PTT 1.12 + Keygen Full ---- xDecoder 14.0 Launcher Package Fix ---- HP Tuners 5.1.1.198 + VCM Keygen FULL ---- SM3 Scanmatik Alpha4 PCMflash ---- JLR SDD ENGINEERING CALCULATOR TOOL ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ---- Zenzefi Aftersales Certificate 23.11.2026 Full ---- Diagbox 7.57 Files Complete Full ---- Man Mantis 12.2025 Full Activated ---- Mercedes WIS ASRA Standalone 10.2021 Activated ---- DTS 9.02 Keygen Patch FULL ---- DTS Monaco 8.16.015 Keygen Patch FULL ---- FoxFlash Offline Loader For KTM 200 Complete ---- DTS Monaco Projects Files Collection FULL ---- Smart 453 0.9 Turbo 66kw - need stage1 file ME17 9.20 ----
Help with Jpro installation
NinJa_ Offline
I'm hoping someone can help me with this issue I have tried to install both jpro 2026 v1 and Jpro 2025 v3 and there both doing the same thing the come up it says active I can connect then it just closes randomly. I have followed the instructions and even uninstalled with revo and cleaned up all files and leftovers also deleted leftover folders. reboot reinstall and I get the same thing. Can someone please lmk what I'm doing wrong or what I can do to fix this.
Thanks given by: Asako , graphicbb , Spawnrn , Asnnuke
MizteriouzA Online
(08-06-2026, 05:00 PM)NinJa_ Wrote: I'm hoping someone can help me with this issue I have tried to install both jpro 2026 v1 and Jpro 2025 v3 and there both doing the same thing the come up it says active I can connect then it just closes randomly. I have followed the instructions and even uninstalled with revo and cleaned up all files and leftovers also deleted leftover folders. reboot reinstall and I get the same thing. Can someone please lmk what I'm doing wrong or what I can do to fix this.
2025v3 has worked for me Ninja with no issues once loaded. You might just need a clean install of windows unfortunately. I don't like those versions since the program has to be re-activated every other time you load them and can get annoying. And since I have a keygen for 2024v3 I just use that one with no issues at all. Hope this helps!
Thanks given by: alisa11 , loganribeiro
