Latest news: ---- MULTI TOOL EC15P FULL ---- PCM Tuner PCM Flash 1.2.7 Activated ---- Synaptic Remover Tool Full ---- Case SR220 SR250 SV250 SV300 Service Repair Manual ---- Hello! ---- Tachosoft 23.1 + Activator Full ---- TIS 2000 + Dongle FULL ---- BMW ISTA+ 4.60.40 Standalone FULL ---- BMW ISTA 4.60.4x AND I-LEVEL OVERVIEW FULL ---- Navkal Pro ECM Programming With Activator ---- CNH Approval Password Generator + Keygen + Keymaker ---- John Deere Payload Encrpt Decrypt + Keygen + Full ---- BMW CAS 1,2,3,3+,4 FG FA TOOL FULL ---- RENAULT DDT2000 FILES COLLECTION MEGA ---- KIA HYUNDAI DTC EDITOR + KEYGEN ---- KIA Variant Codes Files Pack ---- BMW PSdZData 4.60.42 Files FULL ---- MAN KEY CATS TOOL ---- HYUNDAI KIA GDS SOFTWARE FULL ---- John Deere Service Advisor 5.3 2025 ---- HPT To BIN Converter + Keygen ---- MERCEDES SKCV CALC TOOL ---- Toyota Corolla Apple CarPlay Android Auto New Update ---- Help with Jpro installation ---- Pre-installed ODIS 25.0.3 and ODIS Engineering 19 ---- Man Repair Manuals Wiring Schematics Mega ---- PCMflash Original Version Drivers J2534 Wiring FULL ---- ECU Pinouts Collection IMMO Wiring ECU Pictures ---- JCB ServiceMaster 25.1.0 Unlocked + Fix MEGA ---- Best K-Suite Kess K-tag Version Update ----
Help Iveco easy 16.1 e 18.1
Renatoone95 Offline
Iveco
Good afternoon friends, does anyone know why and how to fix the message "you do not have the necessary permission to use this type of function: basic diagnosis" in the Iveco easy 16.1 and 18.1 program?
Thanks given by: talharafique
Irfan796 Offline
what is the process of activation that you use? try to activate with ec-0000--00000 instead of eci serial
Thanks given by: Renatoone95 , Renatoone95 , miguel197742
Renatoone95 Offline
(09-22-2025, 09:00 AM)Irfan796 Wrote: what is the process of activation that you use? try to activate with ec-0000--00000 instead of eci serial
Code:
1-Install the Iveco Easy program.
2-Install the Java environment for your operating system @free from the internet@
3-Run Keygen1.exe
Click: Read current and OK
Click: Generate new and OK
 4-Open E.a.sy on the desktop and close.
5-Run Keygen2.exe @this requires a Java environment@
Set the expiration date
 Select all DVDs
 Set the ECI number. EXAMPLE: EC-01009-04-05-04 c) Click: All
 Click: Get
 After that, you will get the easy_all.txt file in the root of Keygen2.exe.
 Rename: easy_all.txt to actCodes.txt
6-Create a new file ECIs.txt and write your ECI number.  EXAMPLE: EC-01009-04-05-04 f)
7-Copy actCodes.txt + ECIs.txt for Windows XP and Windows 7: C:\Program Files\Eltrac\EASY\Db\Perms
8-Copy the files and folder in the Perms folder (pSets, pSetsNet, rSets, rSetsNet, actCodes.txt, ACIs.txt) replace to
   Windows XP: C:\Documents and Settings\All Users\Application Data\Iveco\Easy\Perms Windows
   windows7: C:\ProgramDATA\Iveco\Easy\Perms
Thanks given by: hobortos , hera26 , CatsEye , stuchan
Irfan796 Offline
Click: Get
this is wrong. eci number should be EC-00000-00-00-00
Click: Get
feel free to contact me through pm for contact info if you still need help, and I will help you via teamviewer
Thanks given by: Renatoone95 , najemk19 , audidoctor
Renatoone95 Offline
Okay, I'll check when I have an answer and I'll let you know here.
s813no Offline
(09-24-2025, 01:32 AM)Renatoone95 Wrote: Okay, I'll check when I have an answer and I'll let you know here.
renatone devi aver sbagliato il copia-incolla dei file
Thanks given by: marj , willi5
Renatoone95 Offline
It worked, friend, with a zero ID the VCI worked.
(09-23-2025, 01:12 PM)Irfan796 Wrote: Defina o número ECI. EXEMPLO: EC-01009-04-05-04 c) Clique: Todos
Clique: Obtenha
isso está errado. O número ECI deve ser EC-00000-00-00-00
Clique: Obter
isto está errado. O número ECI deve ser EC-00000-00-00-00
Sinta-se à vontade para entrar em contato comigo por mensagem privada para obter informações de contato se você ainda precisar de ajuda, e eu o ajudarei através do TeamViewer
(09-26-2025, 10:29 PM)Renatoone95 Wrote: Deu certo, amigo, com ID zero o VCI funcionou.
Thanks given by: octarm2112
yanglf Online
(09-23-2025, 01:12 PM)Irfan796 Wrote: Set the ECI number. EXAMPLE: EC-01009-04-05-04 c) Click: All
Click: Get
Click: Get
i tried to activate using  EC-00000-00-00-00  while generating actCodes.txt and ecis.txt  set  EC-00000-00-00-00
it shows an error no ecu data available
