arar
Nov 2021
Given 0 thank(s) in 0 post(s)
aleksey-
Nov 2019
Given 4840 thank(s) in 575 post(s)
12-02-2021, 12:54 PM
(This post was last modified: 12-02-2021, 12:55 PM by aleksey-.)
Added new version Xentry OpenShell 12.2021 HHT (+C3) DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis L+UEFI) - on torrent
aleksey-
Nov 2019
(12-09-2021, 08:25 AM)automotive15 Wrote: (07-16-2020, 10:55 AM)aleksey-ms Wrote: Xentry OpenShell HHTwin(Full) DAS WIS EPC Starfinder Vediamo Monaco XUS - 06.2021 VHD image - on mega
Image size 256 Gb.
Computer requirements:- HDD or SDD 480 Gb
- RAM 4 Gb
- Processor with support for virtualization technology (enable virtualization in BIOS).
VHD image with Windows 10 LTSC x64 Rus (by default) + English.
Image of programs for the diagnosis, coding, and programming of cars of the Mercedes-Benz concern.
This image contains all the software from various sources, including activators.
This version is a revision and modification of the 03.2021 image, it is fully configured for offline, all offline patches are applied and additional ones are activated. functions for DAS. A patch for Xentry Offline login has been applied. XUS 6.8.0.0 configured and activated! The data map in WIS and EPC has been configured, shortcuts for direct launch are also made, and the transition from Xentry and DAS to WIS is activated (WIS must already be launched before starting Xentry or DAS).
Why VHD and not Acronis? - VHD is a more universal format, you can immediately boot from it without expanding the image by making a couple of clicks in the Easy BCD program. Can be connected to virtual machines. You can deploy it as an acronym or other programs to disk (it is recommended to use VHD2DISK). In two clicks it is mounted in the system and you can take any information from there. Added Strelec WINPE and Rufus to create a bootable USB flash drive for image recovery.
Programs in the image:- Xentry OpenShell 06.2021
- DAS SCN offline coding (SDFlash 07.2018)
- Xentry OpenShell 09.2014 (virtual machine for SD Connect С3 and direct connections to ECU from DAS to HHTwin)
- Xentry Update Service 6.8.0.0
- Vediamo 05.01.01 + configured for С6, Xentry VCI, VCX SE
- DTS Monaco v8.14.016 + projects 2019 (8.16.015 with my activation) + configure for С6, Xentry VCI, VCX SE
- EPC 11.2018
- WIS 10.2020
- StarFinder 2016 (with wiring diagrams) + 2020 (without)
- COMANDDownloadManager login: DLM password: DLM
- HTTwin на Hyper-V password: 111
- FDOK
- MBSeedKey + DLLs 2020
- Seed Calculator + DLLs 2020
- DisassembyAssistant
- Regio ECU 09.2014
- VGSNAG2 Manager v1.6
- SDmedia
- Vediamo and DTS Monaco manuals
Current updates:- Xentry 2021
- Vediamo configured for С6, Xentry VCI, VCX SE
- VGSNAG2 Manager
How to restore any images
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass. You can give me the file password (Torrent) => Xentry Openshell 12.2021 HHT (+ C3) das wis epc starfinder Vediamo monaco.
please....
aleksey-
Nov 2019
Added Xentry OpenShell 12.2021 HHT (+C3) DAS WIS EPC STARFINDER VEDIAMO MONACO on mega
MBMaranoT
Nov 2021
Given 21 thank(s) in 4 post(s)
aleksey-
Nov 2019
aleksey-
Nov 2019
Added new image Xentry OpenShell 09.2022 HHT (+C3) WIS EPC Starfinder Vediamo Monaco (Acronis L+UEFI)
aleksey-
Nov 2019
Added new image Xentry OpenShell 12.2022 HHT (+C3) WIS EPC Starfinder Vediamo Monaco (Acronis L+UEFI)
Illoolli
Mar 2022
Given 27 thank(s) in 6 post(s)
12-11-2022, 07:47 PM
(07-16-2020, 10:55 AM)aleksey-ms Wrote: Xentry OpenShell 12.2022 HHT (+C3) DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis L+UEFI) - mega
- RAM 4 Gb
This version is a revision and modification of the 06.2022 image, it is fully configured for offline, all offline patches are applied and additional ones are activated. functions for DAS. A patch for Xentry Offline login has been applied. XUS 6.8.0.0 configured and activated! The data map in WIS and EPC has been configured, shortcuts for direct launch are also made, and the transition from Xentry and DAS to WIS is activated (WIS must already be launched before starting Xentry or DAS).
Programs in the image:- Xentry OpenShell 12.2022
- Xentry Update Service 6.9.0.0
- DTS Monaco v8.14.016 + projects 2022 (8.16.015 with my activation) + configure for С6, Xentry VCI, VCX SE
- EPC 11.2018
- WIS 10.2020
- WIS standalone 2021/07
- FDOK
- Regio ECU 09.2014
- SDmedia
![[Image: 8c0a012facb7e902de5b4470dae7c673.jpg]](https://i116.fastpic.org/big/2022/0308/73/8c0a012facb7e902de5b4470dae7c673.jpg)
pass please
aleksey-
Nov 2019
(12-11-2022, 07:47 PM)Illoolli Wrote: (07-16-2020, 10:55 AM)aleksey-ms Wrote: Xentry OpenShell 12.2022 HHT (+C3) DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis L+UEFI) - mega
- RAM 4 Gb
- EPC 11.2018
- WIS 10.2020
- FDOK
- Regio ECU 09.2014
- SDmedia
pass please Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
