Latest news: ---- DTS 9.04.0016 License TOOL ---- Elite Convert Winols KP Files Tool ---- WEBASTO DIAGNOSTIC WTT V3.8 NEW UPDATE ---- PCMflash Dongle Emulator V0.1.2 For Versions 1.2.0 And 1.2.1 ---- BMW Standard Tools 2.12 FULL ---- BMW CIC Patcher v2 Generate Your Retrofit FSC Certificates ---- MB SeedKey Generator Complete Software ---- BMW ISTA 4.62.2x VERSION I-LEVEL OVERVIEW ---- TOYOTA LEXUS TUNER V2 FULL ---- PCMflash 1.2.0 - 1.2.1 Dongle Security TOOL ---- DTSProjects for DTS 9.04.016 ---- DTS 9.04.016 FULL PATCH ---- GM TIS2000 NAO Virtual Machine New Update ---- DRB III Emulator Virtual Machine New Update ---- Bosch ECU Database v0.3 Tool ---- ZenZefi After Sales Standard Valid Until 2027.02.17 ---- EDC17 IMMO SERVICE TOOL ---- Davinci Deluxe 1.0.XX.0 Full ---- MULTI EDITOR BY DR SALEH FULL ---- Zenzefi Aftersales Certificate 17.02.2027 + 26.11.2026 ---- Lsuite Checksum Tool Full ---- Kubota Service Manuals (FSM) Collection ---- DTS Monaco 8.16.015 Install + Patch + Keygen FULL ---- Multi Editor Honda 1.39.1.0.0 Full ---- Clone OpenPort 2.0 Windows 11 Driver ---- FTAG Checksums Test Fix TOOL ---- DTS Monaco 9.02 Install + Patch + Keygen FULL ---- PCMflash Dongle Manager 0.1.2 China Dongle Emulator ---- Zenzefi Aftersales Certificate 17.02.2027 ---- IMMO SERVICE TOOL 1.2 + INSTRUCTION FULL ----
Xentry OpenShell 12.2023 HHT (+C3) WIS EPC Vediamo Monaco (Acronis L+UEFI)
Mercedes
Xenty Cars OpenShell 12.2023 (terabox) + All OpenShell 09.2023 (torrent) HHT (+C3) DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis L+UEFI)
Computer requirements:
  • HDD or SDD 480 Gb
  • RAM 4 Gb
  • Processor with support for virtualization technology (enable virtualization in BIOS).
VHD image with Windows 10 LTSC x64 Rus (by default) + English.
This version is a revision and modification of the 03.2023 image, it is fully configured for offline, all offline patches are applied and additional ones are activated. functions for DAS. A patch for Xentry Offline login has been applied. XUS 6.8.0.0 configured and activated! The data map in WIS and EPC has been configured, shortcuts for direct launch are also made, and the transition from Xentry and DAS to WIS is activated (WIS must already be launched before starting Xentry or DAS).
Why VHD and not Acronis? - VHD is a more universal format, you can immediately boot from it without expanding the image by making a couple of clicks in the Easy BCD program. Can be connected to virtual machines. You can deploy it as an acronym or other programs to disk (it is recommended to use VHD2DISK). In two clicks it is mounted in the system and you can take any information from there. Added Strelec WINPE and Rufus to create a bootable USB flash drive for image recovery.
Programs in the image:
  • Xentry OpenShell 09.2023
  • DAS SCN offline coding (SDFlash 07.2018)
  • Xentry OpenShell 09.2014 (virtual machine for SD Connect С3 and direct connections to ECU from DAS to HHTwin)
  • Xentry Update Service 6.9.0.0
  • Vediamo 05.01.01 + configured for С6, Xentry VCI, VCX SE
  • DTS Monaco v8.14.016 + projects 2022 (8.16.015 with my activation) + configure for С6, Xentry VCI, VCX SE
  • EPC 11.2018
  • WIS 10.2020
  • WIS standalone 2021/07
  • StarFinder 2016 (with wiring diagrams) + 2020 (without)
  • COMANDDownloadManager login: DLM password: DLM
  • HTTwin на Hyper-V password: 111
  • FDOK
  • MBSeedKey + DLLs 2020
  • Seed Calculator + DLLs 2020
  • DisassembyAssistant
  • Regio ECU 09.2014
  • VGSNAG2 Manager v1.6
  • SDmedia
  • Vediamo and DTS Monaco manuals
[Image: 78ad0af9046136bcef46cfc240fbecc0.jpg]
[Image: 8c0a012facb7e902de5b4470dae7c673.jpg]
(07-22-2020, 06:03 PM)djfelixrs Wrote: Which configuration to use in the bios to restore? UEFI or LEGACY?
LEGACY
passionbmw Offline
it ok
Thanks given by: Bartonnzd
Added doc - How to change language on HHTWin, How to change language in Mercedes SDConnect Toolkit
Thanks given by: RidgecokS
Updated my full Mercedes Acronis image.
What's new:
Xentry OpenShell 20.9.4 09.2020
WIS 07.2020
Seed Calculator
Selit
DisassembyAssistant
Added a new image with updated Xentry 03.2021 and Starfinder 2020
Thanks given by: Prodrive , Galenot
Added new version Xentry OpenShell 06.2021 HHTwin(Full+C3) DAS WIS EPC STARFINDER VEDIAMO MONACO XUS (VHD) [06.2021]
Thanks given by: Galenot , Keganguew
Add updates on the new image version.
Added video How to restore any images
Added new version Xentry OpenShell 09.2021 HHTwin(Full+C3) DAS WIS EPC STARFINDER VEDIAMO MONACO XUS (VHD) [09.2021]
