ADS DPF EGR REMOVER + ACTIVATION
(04-11-2024, 10:03 AM)kar33m Wrote:
(04-08-2024, 07:34 PM)Prodrive Wrote: See this image
[Image: hwid.jpg]
@ Prodrive
Bro Thanks for being so understanding and suporting , i feel glad to have contrubuted a dontation to the group!
heres my code
MMw6xTlup3d30Y/7hI2ydA==
i cant seem to get it to activate though?
i also tried to run the KG in your last post but that also doesnt want to play ;/
Thanks given by: kar33m
kar33m Offline
Thanks again for A+ support!
I'm 1/3 the way there haha
The EGR remover app works now
The lambda remover and the DPF remover ( DPF is the goal atm ) still won't open and give a message box explaining my HWID is copied to clipboard and then the code
I got a pic but nit sure how to share it
Copy "code.key" into three folder
C:\Program Files\DKteam Software\DPF Remover
C:\Program Files\DKteam Software\EGR Remover
C:\Program Files\DKteam Software\Lambda Remover
namm Offline
Hi,
activate pls.
HWID - hJDIW132GfDHpOt0TL*!cQ==
Thank you
(04-19-2024, 11:19 AM)namm Wrote: Hi,
activate pls.
Thank you
Please enter valid hardware ID
namm Offline
activate pls.
HWID - hJDIW132GfDHpOt0TL81cQ==
Thank you
activate pls.
Thank you
namm Offline
activate pls.
Thank you
sorry here - hJDIW132GfDHpOt0TL81cQ==
activate pls.
Thank you
Thanks given by: namm
SpTec Offline
Hi.
Thanks for sharing
Protection
VAJKYk1MiTq/hG9vhHJ0Dw==
OK
daddy76, 7 Guest(s)
