Latest news: ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ---- Volvo Tech Tool PTT 1.12 + Keygen Full ----
ADS DPF EGR REMOVER + ACTIVATION
Free service for activation
Put here your HWID
Copy "code.key" into three folder
C:\Program Files\DKteam Software\DPF Remover
C:\Program Files\DKteam Software\EGR Remover
C:\Program Files\DKteam Software\Lambda Remover
kar33m Offline
HWID
Your HWID(copied to clipboard) is : aIDThTlup3crYMWbmrJlN7pO5T0uu/EPriM2Cw==[E7F10655|2AD24D64]
OK
Thanks given by: knaak11088 , diag71 , SteveGeate
Invalid your hardware id
Thanks given by: carlos647 , keeperita
kar33m Offline
thanks for the reply, sorry i dont understand what you mean?
are meaning my hardware isnt compatible/ working correctly?
Thanks given by: Keithnem , cengiz20 , cooko , deeagsm , specimenu , phucngo
(04-08-2024, 05:53 PM)kar33m Wrote: thanks for the reply, sorry i dont understand what you mean?
Post your hwid correct
Thanks given by: FrankBls , motifxf
kar33m Offline
Thanks given by: mecanicos , Houngsan
See this image
[Image: hwid.jpg]
Thanks given by: sapopt , Caster01
simon1985 Offline
(11-05-2022, 06:32 PM)Prodrive Wrote: ADS DPF EGR REMOVER + ACTIVATION
Put here your HWID
TOLyp/2rcQ4zwyzm6DgBZA==
Thanks given by: policemarley , rook92 , phucngo , billicasu
Put here your HWID
Thanks given by: mobens , imbus , bennybunnys , Ben190807 , Orlandoshurn
kar33m Offline
(04-08-2024, 07:34 PM)Prodrive Wrote: See this image
[Image: hwid.jpg]
@ Prodrive
Bro Thanks for being so understanding and suporting , i feel glad to have contrubuted a dontation to the group!
heres my code
MMw6xTlup3d30Y/7hI2ydA==
i cant seem to get it to activate though?
i also tried to run the KG in your last post but that also doesnt want to play ;/
Thanks given by: cleberfpr
