INSTRUCTIONS:
1) Disable Internet and antivirus
* Change the date of your Windows to 24-10-2018 *
2) If you had Rhinoceros 6, make sure to delete the Rhinocore.dll file from the folder where you have Rhinoceros installed (\ Rhino6 \ System).
3) Reinstall Rhinoceros 6 and select REPAIR
4) Launch Rhino 6 and select "Enter your license key"
5) Start the file RH6KEYS.exe from 2.PATCH and use the LKEY as license, do not close the RH6KEYS.exe
5) In license location, select “Use license only on this computer” and accept with YES.
6) Select Manual Validation and use the RH6KEYS.exe from step 5.
7) Start Rhino 7 WIP
NOTE:
-Don't add the license to your Rhino account
-The keys are validated from October 2018, in this case you have to change the date of your PC to 10-24-2018 to be able to use the activation. You can then restart Rhino and return your time to the correct date as well as activate the internet.
NOTE:
