Latest news: ---- MG1CS008 Bench Unlock ---- Toyota EPC 2023 ---- Range Rover FRM3 BCM Repair Tool ---- Bendix ACom 6Pack 6.18.6.9 File Mega ---- Simplo 2025 ---- Autocom 2021 ---- Ecusprog V1 ---- HardCut Limiter Petrol Engines Tool ---- VOLVO ECU LOADER TOOL ---- VCAP Interpreter GM Opel SPS Controller ---- HONDA EDITOR + LOADER FULL ---- VCDS ATMEGA162 HEX CAN+ USB Loader v9.2 FULL ---- XENTRY 06.2026 RELEASE 4 LAST ---- VAG TOOL MK EOI SOI EDC17 v1.1 FULL ---- RENAULT DACIA PROG 42 FULL SOLUTION ---- VAG Odis Licenses EU ---- CAN CLIP DLL FILES ---- BMW Esys Plus 3.8.1 With KeyGen FULL ---- DriverEasy Pro 7.1.2.0 + Fix Full ---- Nitro PDF Pro Enterprise 26.0.8.0 + Patch Full ---- Vediamo MOE Engineer System Training Book ---- Sirius32 EMS3132 Tool Full ---- Engine ECU Decoding Multi Brand Tool ---- Flex MMF tool Encrypt / Decrypt ---- Renault Can Clip 200 ISO File Mega ---- SW Finder 6.1.3 TOOL ---- Flash Files Downloader Tool ---- Odis Service 25.3.0 + Odis Engineering 21.0.1 - 2026.03 Full ---- VAG TOOL Operating Point Analyzer Target EOI SOI ---- Renault Scenic III 2013-2016 Service Repair Manual ----
Delphi Autocom - NEW 2021
Teppei1981 Offline
Good Afternoon!
Please, is it possible to know the activation procedure?
Thank you very much!
Thanks given by: Spermix
Teppei1981 Offline
Good evening,
I'll run some tests and update you.
Thank you very much
Teppei1981 Offline
(10-19-2021, 06:52 PM)Teppei1981 Wrote: Good evening,
Thank you very much
Good morning,
I have tried activation but the error message appears:
Wrong file or different pat** user to generate FileAct******.XML
nikolja Offline
How to activate?
Thanks given by: Robertjax
Teppei1981 Offline
Good evening,
Are there any updates to this?
Thanks a lot to everyone!
nemesis3290 Offline
(10-29-2021, 08:36 PM)Teppei1981 Wrote: upgrade?
Thanks!
hello post here your activation file see if I can do the magic
Thanks given by: Teppei1981 , Teppei1981
Teppei1981 Offline
Thanks!
Hi nemesis3290!
Here is the attached FileActivation file.
You should only change the extension to *.xml.
Thank you for your valuable support!
Thanks given by: marjan47 , marjan47 , figi , figi
nemesis3290 Offline
Thanks!
Hi nemesis3290!
hello try and report remember that if I helped you thank and rep
Thanks!
Hi nemesis3290!
Thanks given by: Teppei1981 , Robertjax , marjan47 , marjan47 , Admin , Admin
Teppei1981 Offline
Opel
Thanks!
Hi nemesis3290!
Thanks!
Hi nemesis3290!
Thank you very much, Nemesis3290!
Everything is working fine now!
