Latest news: ---- BMW Easy Connect v1.1 New Update ---- ZF Transmission Repair Manual Package ---- help please DAF v95 full installation and Turkish language support ---- BMW ISTA Launcher Console 1.2.4.14 TOOL ---- BMW Psdzdata Torrents Files Collection ---- iDecoder 4.5 No Registration Full ---- BMW ISTA Standalone 4.61.12 Files FULL ---- Renault CAN Clip 222 Scanmatik J2534 Full ---- ODIS Service 26.0 + ODIS Engineering 22 Torrent Files FULL ---- BMW ISTA GUI 2.0.1 NEW UPDATE ---- BMW Standard Tools 2.12.7 Software FULL ---- VAG IMMO TOOL NEW UPDATE ---- Hyundai Heavy Equipment Factory Service Manuals ---- DAF XDC II 5.61 v95.00 + DEVKIT TOOL FULL ---- Truck Explorer Software Files Mega ---- scania sdp3 ---- Caterpillar Factory Password Keygen Full ---- Pump Diagnostics BOSСH VP44 VP30 Files ---- MITSUBISHI SEPE + MUT3-SE 2024.12 FULL ---- Mazda IDS v140 File MEGA ---- WABCO TEBS-E 7.00 LANG ENG FILES ---- JPRO CURRENT VERSION 2026 v1.2 FILES ---- FRM BMW DFLASH DATABASE FILES ---- BMW E-sys 3.8.1 + Patch And Keygen ---- Davinci Deluxe Edition 2025 v1.0.37 Full Token ---- XPROG 5.5.5 NO DONGLE NEED FULL ---- SCANIA SDP3 V2.70.1.3 FULL TRUCKS + MARINE + KEYGEN ---- BMW ISTA Updater GUI 2.0.0 TOOL ---- Bendix VCP ---- BMW Easy Connect ECC ISTA TOOL ----
SDConnect unlock dump!!! 100% working solution.
badik Offline
Mercedes
This is a dump read out from PIC16LF88 chip of my own SDConnect C4 device (4-5 years old). It's 100% working.
I know it exactly because I've succesfully unlocked 3 units for last 2 days using it. Each one works fine.
You don't need to buy a new one PIC16FL88. You just have to program chip from your own device.
After that when you run your SDconnect you will probably see that serial number, OS version of your device are changed into zeroes "0000".
Don't worry. Just change your C4 to factory state using buttons near by LCD (no need to explain "How to..." because it's quite clear). After rebooting you'll see actual SN, OS version and so on.
Also you can change serial number of your device. 24c02 contains it. After changing number just run "factory settings" function...other way it will not change. After reboot you'll probably see (on lcd of your device) your SN looks like "the number you've programmed into chip +1"... I mean 10001 inspite of 10000 for example and so on, but in SDNC tool kit you'll see the real SN (10000), and after succesfull reconfiguring your device you'll see the right number on LCD of your C4.
I was using cheap ssop28 (0.65mm step) adapter and Pickit3 programmer to read/write PIC16lf88. This scheme made for Pickit3 OEM socket(ICSP).
Also I've got dumps of both flashes 29f016 and PIC18lf8680 if somebody need it.
Archive is protected. Pass via PM
If somebody needed than there are dump of EEPROM 24cxx with example of serial number and PM pic dump
Somebody asked me if I have dumps of both flash memories 29f016. Finally I've found them. In the picture below you can see marks A & B made with pencil and dumps in archive are also named according to signs in the picture.
One of archives (probably - device1) contains dumps from device which didn't support command CE_flash_loeschen and the other one ( it seems device2) contains dums from working SDConnect.
I read them both using Triton 5.7 programmer with hand-made adapter for 8-bit flash memories (29XXXX).
If you try to read-write them using TL866/wizardprog/willem...then don't waste your time. These programmers won't dothis job. But it was few years ago, so probably something changed.
