(11-25-2022, 06:38 PM)aleksey-ms Wrote: Added VAG ETKA 8.2 (1474)
Hello Aleksey,
I have a hiccup with the installation. After everything is installed correctly by using the instructions .txt, when i run Ekta, i get myself this message:
information über den vorhandenen Hardlock
Version der DLL 2.12
Beim Ansprechen des Hardlocks trat der Fehler 7 auf
Translation by the holy google:
information about the existing hardlock
version of the DLL 2.12
Error 7 occurred when addressing the hardlock
Tried the following steps to address the issue:
- performed an uninstallation of Ekta, with registry cleanup to ensure a clean entry of the reg files. (HKEY_CLASSES_ROOT, HKEY_CURRENT_USER, HKEY_LOCAL_MACHINE entries were deleted accordingly, and checking USERS & CURRENT_CONFIG revealed no extra reg entries)
- doublechecked for any residual files/folders
- reinstalled with the same error afterwards.
Tested on Win7 x64 hardcase laptop used primarily for auto diagnose for VAG cars (VCDS however is not yet present as it is a fresh OS install and i wanted to start off with EKTA before VCDS).
Please advise if you happen to know a way around this. I am sorely tempted to nuke and reinstall the OS but i'd love to avoid that
Cheers from Bucharest!
