Latest news: ---- Volvo Tech Tool Devtool License Editor Keygen Full ---- Fiat ecu map ---- SVEdit v1.1.38 ---- BMW E-SYS PSdZData Tool New Version Link MEGA ---- VEDIAMO PASSTHRU 5.1.1 + KG + PATCH ---- GM ECU FLASHER TOOL FIX ---- BMW CODING PACK FILES MEGA ---- iDecoder 4.5 No HWID Full ---- ECU Tuning Solutions 1.02 No HWID ---- VCDS HEX NET SUPPORT WIFI DOIP TOOL ---- BMW ETK Price 11.2026 ---- K-Suite Collection Professional Software Kess V2 K-TAG ---- GM GDS2 SOFTWARE + KEYGEN + PATCH ---- ECU Repair Guide Electronic Tool 2022 ---- BMW E-Sys 26.04.02 New Version MEGA ---- Best K-Suite Version For Kess 5.017 K-Tag 7.020 ---- Immo Doctor 2.1 + Multi Editor + DTC Off + Keygen ---- Subaru SSM3 Universal J2534 04.04 Patch Full ---- SCANIA SDP3 TRUCKS + MARINE + KEYGEN ---- CUMMINS INSITE 9.3.1-10.0-10.1 PATCH FIX TOOL ---- Iveco Power Trucks Buses 2020 Full MEGA ---- Lsuite 1.2 Checksum Tool Full ---- Ksuite For Ktag 7.020 ---- Lsuite 1.03 v2 Checksum Tool Full ---- PCMFlash ECU Master KTM 1.20 ---- DTS Monaco 9.04.16 Activation TOOL ---- NYO 4.0 (2017) Full + Pictures Tested Working ---- Hello from Germany ---- Renault VCI3 (V240) Complete + Activator ---- Dialogys 4.78 Renault Dacia Workshop Manuals Electronic Parts Catalog ----
Remote Install - Scania Multi, SDP3, XCOM, BNS II Service Tool (BST)
Remote Install - Scania Multi, SDP3, SDP2, XCOM, BNS II Service Tool (BST)
Scania Multi 10.2024 online (via remote desktop) 12 months - $135
Scania Multi 10.2024 online (via remote desktop) 3 months - $59
Scania Multi 10.2024 online (via remote desktop) 1 month - $35
Scania Multi 03.2024 - $190
Scania Multi 2022 - $65
Scania Multi 2020 - $35
Scania Multi is a car dealership aftermarket service. The program contains a catalog for the selection of spare parts and electronic manuals for repair and maintenance. Scania Multi works by VIN code and uses only the last 7 digits to decrypt the wines of a bus or truck. In the program there is a search by the part number, you can find out its applicability, as well as get information about the re-release of parts.
[Image: Scania-Multi.jpg]
Scania SDP3 2.58.3 Truck, Bus, Marine (with keygen) - $299
Scania SDP3 2.60 Truck, Bus, Marine - $155
Scania SDP3 2.54 for Truck and Bus (with keygen) - $155
Scania SDP3 2.64.1 Truck, Bus - $165
Scania SDP3 2.48 2021 - $35
SDP3 - Scania Diagnos + Programmer 3 (SDP3) software is designed for the diagnosis of Scania trucks and Scania industrial and marine engines. Connection to the electronic control units is done using the Scania VCI 2 or Scania VCI 3 interfaces. Depending on the version of the program, it supports work with all Scania trucks manufactured from 2004 to the present day.
[Image: Scania-SDP3.jpg]
Scania XCOM - $29
Scania XCOM - is a diagnostic tool to read, save, and modify ECU data such as trouble codes, parameters, statistic data etc. VCI2/VCI3 interface is used to connect to ECU via CAN protocol.
Supported modification of ECU data of the following types:
  • EMS – Engine management system
  • GMS – Gearbox management system
  • RET – Retarder system
  • AWD – All-wheel drive system
  • CLS – Clutch Control
  • EEC – Exhaust Emission Control
  • COO (COO7) – Coordinator
  • BWS (BCI1) – Bodywork system.
[Image: Scania-XCOM.jpg]
Scania Developer (CDEV - ECOM - XCOM) - $299
Scania CDEV supports the following operations:
  • Read ECU ID, data, parameters, fingerprint.
  • Read and erase DTC.
  • SparePart program all systems.
  • Gather all data for field test functions.
  • Load, modify, compare SOPS files.
Scania ECOM - is a program that, together with the VCI2, enables the communication between your PC and the control unit (EMS S6) on the engine.
You can carry out the following operations with ECOM:
  • Read stored fault codes and Freeze Frames.
  • Clear inactive fault codes.
  • Read information about stored working cycles.
  • Measure internal variables such as the engine speed, pressure, temperature and save them to a file.
  • Program certain parameters.
Scania BNS II Service Tool (BST) - $39
Scania BNS II Service Tool (BST) is a PC-based diagnostic program for troubleshooting and programming of the electrical system in the bodywork of Scania OmniCity, OmniLink, and Citywide buses.
[Image: Scania-BNS-II-Service-Tool-BST.jpg]
Scania SOPS - $59
The program encrypts/decrypts SOPS files (contains data on parameters and specifications of all blocks of trucks or buses). Files can be downloaded using Scania VCI2.
Scania SOPS Editor Euro-6 2022 Unlimited - $570
Supports EURO 6 Scania Sops File Encryptor/Descriptor.
  • Disable AdBlue
  • Disable EGR
  • Disable Immobilizer
  • Change VIN
  • Disable Nox Control
  • Disable Torque Reduction NOx Control
  • Disable Modify more than 300 other parameters...
    [Image: Scania-SOPS-Editor-Euro-6.jpg]
    Scania AdBlue Off Remover with short instructions - $45
    [Image: Scania-Ad-Blue-Off.jpg]
    Scania IMMO Pin Code Decryption 4.02 (activation 1 PC) - $165
    Scania IMMO Pin Code Decryption 6 (activation 1 PC) - $215
    Scania IMMO Pin Code Decryption 5 (activation 1 PC) - $189
  • It works with - ASSY, COO6, COO7, COO8, EMS S6/S7/S8/EMD1, LAS1/LAS2
    [Image: Scania-IMMO-Pin-Code-Decryption.jpg]
  • Need it? Write to me to discuss.
Added:
Scania SDP3 2020
Scania SOPS
Added Scania SP2, SD2
Added Scania Multi 2021
Added:
Scania Multi 10.2021 online (via remote desktop) 12 months
Scania Multi 10.2021 online (via remote desktop) 3 months
Scania Multi 10.2021 online (via remote desktop) 1 month
Added Scania Multi 2022
Scania SDP3 2.51 2022 Engine Marine Industrial, Truck Bus
Thanks given by: TALLERARGA
Added Scania SDP3 2.52
Added Scania Diagnos & Programmer SDP3 2.52
Added
Added
Scania SDP3 2.53.3 for Truck and Bus (with keygen)
Scania SDP3 2.53.3 for Engine Marine Industrial (with keygen)
