CAT ET 2020B WITH FACTORY PASSWORD
dnat43701 Offline
NO LONGER HAVE THESE FILES. SORRY
dnat43701 Offline
(12-04-2020, 02:13 AM)abatta12 Wrote: plz send me lic.hwid file attach. thankyou
If I don't see a thank you or rep from you I will not send you a .lic file.  Click the thanks
Thanks given by: culatas
dnat43701 Offline
(12-04-2020, 04:29 AM)Dejalue Wrote: great post....key please for the file....
Check your PM. Thank you !
dnat43701 Offline
(12-05-2020, 03:06 AM)Dejalue Wrote: HWID....PASSWORD PLEASE...THANKS
Thanks given by: Admin , Prodrive
dnat43701 Offline
I'm trapped in the house all weekend, and bored AF! Anyone needing ET2020B activated or help with installing it let me know.
Thanks given by: Dejalue , godinhojr
Ahmedses Offline
(12-04-2020, 01:28 AM)dnat43701 Wrote: Hello all!! I can activate CAT ET 2020B with Factory Password (AUTOGEN) I will try to be a quick as I can be with the replies. Please remember to click the thank you and rep.
It would probably be easier on me if you were to pm me your HWID6. I will include the link which will have all of the install plus the patch files. You will just have to add the .lic file to your comet and flash folders. those of you that are one of the ones that have a hard on for an antivirus ( other than defender)  make sure that it is shut off including windows defender before you even begin to download the files.
install 2020b.exe
run the hwid6 and PM me your HWID.
place  the et2020b.lic file in the two folders below
for_users\dll_for_Comet
or_users\dll_for_FlashServer
then copy the CONTENTS OF  dll_for comet to C:\Program Files (x86)\Common Files\Offboard Information Products\2020A\Comet
then copy the CONTENTS OF dll_for_flashserver to C:\Program Files (x86)\Common Files\Offboard Information Products\2020A\Flash
Then right click the set_level. and select merge.
Make sure that you exclude C:\Program Files (x86)\Common Files\Offboard Information Products 2020B from your antivirus.
RUN 2020B as admin. Once CAT ET 2020B is open press ctrl+f2 or FN+ctrl+f2 to open the Factory password.
I will have only have this posted for a limited time.  If I don't see a thank you or rep from you I will not send you a .lic file.
Yes if you have an older version of ET installed you'll have to use Revo or equivalent  to remove it.
No I don't have a Keygen for the Keymaker to sell. (I wish that I did.)
For the one that come back and say that it stopped working after you restarted you computer. Check your anti virus because I would about bet that your antivirus has blocked, deleted or quarantined one of your .dll's.
Link Password and HWID6 Please Thanks and Rep Done
Thanks given by: brokencoal , brokencoal
Geovane94 Offline
install 2020b.exe
send me link friend  thanks  !
Thanks given by: cealemas , cealemas
