Flex MagicMotorsport - Best Chip Tuning Tool
Hardware
Flex ChipTuning tool (programmer for ECU, TCU) - $1320
Flex is the tool that allows you to remap, update and repair ECUs and TCUs for cars, bikes and trucks. With Flex you have everything you need to start working in the world of chiptuning and boost your business.
The programmer supports all available connection modes. You can easily connect to most of the car ECUs via the vehicle's OBD port. While, for more advanced jobs, BDM, Bootloader and JTAG modes are also possible.
What inside:
Cabling kit: FLX3.5 color coded wiring harness
Adapter kit: 6 pcs set of pin adapters to FLX35
FLEX Base Module
FlexBox Module for FLEX
Connection cable OBD: FLEX to CAN/Kline RED
Connection cable OBD: FLEX to ENet GREEN
Connection cable: FlexBox port C to NEC 7F00 XX
Connection cable: FlexBox port D to BDM MPC5xx
Connection cable: USB 2.0 AM-BM BLK 1.8m
FlexBox port E 40 pin adapter for FLK35
FLEX & FlexBox diagnostic adapter
Switch Mode Power Supply for FLEX with plugs
FLEX Branded Box
![[Image: FLK02-FLX1-1-FLX1-9-2.jpg]](https://i.postimg.cc/LXjGFkkq/FLK02-FLX1-1-FLX1-9-2.jpg)
MAGBench BDM + Jig Tool Kit - $635
It allows you to make stable connections with engine control units and automatic transmission units in Boot, JTAG and BDM modes.
![[Image: FLK08-1-1.jpg]](https://i.postimg.cc/sDJGK18s/FLK08-1-1.jpg)
Software
Full Flex Master - $5390
Full Flex Slave - $1815
OBD + Bench Flex Master - $2640
OBD + Bench Flex Slave - $990
Flex Full Master software package puts at your disposal all the protocols available for the more than 25,000 vehicles supported by Flex, also make you able to program in the three connection modes.
Flex Full Slave supports more than 9,000 vehicles and users can rely on the release of new SW protocols by MMS.
OBD + Bench Flex Master is the ideal solution for each tuner who want to have all the protocols for engine ECUs of cars, motorcycles and vans in OBD and Bench mode. Modify and recalibrate using the Flex programmer without the need to open the electronic unit.
If you need it to write me for details.
Hardware
What inside:
FLEX Base Module
FLEX Branded Box
Software
