Latest news: ---- SIMOS PCR 2.1 IMMO OFF Solution All Tools Supported ---- KIA HYUNDAI DTC EDITOR FULL ---- HYUNDAI AUTOCALC TOOL ---- Volvo Premium Tech Tool PTT + Activator Full ---- RENAULT DACIA DELPHI DCM34 TOOL ---- IMMO SOFTWARE PACK COLLECTION ---- HONDA EDITOR 1.39 + LOADER FULL ---- TOYOTA REPAIR MANUAL WIRING DIAGRAM ---- VCDS 25.3.0 + V2PP LOADER VERSION 2531 1.07.18 UPDATE 4 ---- Consulting Tuning Database B + C Files ---- DTS MONACO Super Engineer System Training Book By Moe Diatronic ---- ECU Repair Program DataSheet 2.0 FULL ---- Nissan NATS 5 - 6 PIN Code Calculator ---- ToyoLex 4 + KEYGEN Full ---- Bosch ECU Database v03 FULL ---- VAG Dash Editor TOOL ---- EFFI Key Programmer With 173 Modules FULL ---- DAVINCI DELUXE 1.0.35 FULL WORK ---- Alpha Calculator Decoding Software ---- ECU TUNING SOLUTIONS 1.01 + KEYGEN ---- BMW CIC MID PATCH TOOL ---- Hello form Bosnia ---- Xentry FullFix v4.9.4 Activation ---- MERCEDES WIS STANDALONE 07.2021 FULL ---- Range Rover 2020 Wiring Diagram ---- Land Rover Freelander 2 2014 Wiring Diagram ---- EDC16 Eeprom Checksum TOOL ---- BMW FRM3 Repair TOOL ---- Binary Files Inspector Tool ---- Ksuite 2.80 - chiptuning software ----
Caterpillar Electronic Technician CAT ET 2024C
CAT
Caterpillar Electronic Technician CAT ET 2024c (just link for the program)
It is an electronic diagnostic software required for communication, diagnostics, and maintenance. Tracked engines and machines.
Added a new version - CAT ET 2020C
Added a new version - CAT ET 2021A
Thanks given by: Prodrive
landero Offline
Wrong link
Prodrive Offline
(03-12-2021, 05:41 AM)landero Wrote: Wrong link
Caterpillar Electronic Technician CAT ET 2021A - Mega
Updated link
Added video with the program.
DUPA Offline
Please don't GET SO HOT !!!!!
I have yet to see a crack for JPRO 2019 / 2020 /2021 done properly. First off, you will need a loader that updates the date in the lic.dat file each time program is loaded. Second, you will need to patch/update/replace the databases, not only volvo/mack but also the main one the program uses to check compatibility of bidirectional. Otherwise you will be missing many of the options that normal JPRO 2019/2020/2021 has under bidirectional tests. There is even more to doing this properly such as patching out the other license checks or blocking in internal firewall.
Added new version Caterpillar Electronic Technician CAT ET 2021B - Mega
Thanks given by: mot1988
Added new version Caterpillar Electronic Technician CAT ET 2021C
