Latest news: ---- Smart 453 0.9 Turbo 66kw - need stage1 file ME17 9.20 ---- WinOLS 4.7 Native Installer + Complete Guide ---- Iveco Easy 18.1 Trucks + Buses + Keygen + Instruction ---- VCDS LASTEST VERSION FILES MEGA ---- ECM Titanium 40.000 Drivers Chip Tuning Firmware Editor ---- UPA SOFTWARE + SCRIPTS COLLECTION FULL ---- Ecu Connections All Cars Tool ---- DTS Monaco 9.02 + Patch + Keygen + Projects Full ---- Easy Kill v2.0 Start-Stop Off Tool ---- iDecoder 4.5 Ultimate Automotive ECU Immo Solution ---- ECU Repair Guide 2022 TOOL ---- Challenger TerraGator 3244 Service manual ---- JPRO 2026 v1.1 WITH ACTIVATION FULL ---- BMW ISTA Voltage Terminal Warning Disabler TOOL ---- PCR2.1 UNLOCKER TOOL FULL ---- IMMO Universal Decoding 3.5 Delete IMMO OFF ECU ---- BMW Easy Connect 2 v1.6 TOOL ---- Cmp Hex Tool Full ---- DTS Monaco 9.02 + Keygen + Patch FULL ---- Mercedes Gear Tool Full ---- Scania Xcom 2.54 + Plugin Full ---- GPEC2 GPEC2A FIRMWARES + KEYGEN ---- BMW ISTA-P 3.75.0.400 Modified ICOM A1 A2 Support ---- Complete Automotive Workshop Software Collection Full Version ---- Automatic Transmission Repair Manuals Rebuild Parts ---- BMW ISPI ISTA Launcher Offline Version MEGA ---- Bosch ESI [tronic] 2014 DVD1+DVD2+DVD3 Diagnostic Software ---- L-Suite Checksum Tool 1.03 Full Pack With KSuite DLLs ---- Actia Multidiag J2534 PassThru Support Full ---- hello from norway ----
Carly Pro 49.40 All Car Brands (phone diagnostics)
Carly Pro 49.40 Full Unlocked All Car Brands (phone diagnostics)
These are supported by the following car brands: Audi, BMW, Lexus, Mercedes, Mini, Porsche, Renault, Seat, Skoda, Toyota, and VW. Every car is unique, so specific features will vary with every model, build year, hardware, and software.
Check the car’s health and save money
With Carly car diagnostics, you’ll have the right scanner tool to read from all built-in electronic control units (ECUs), including engine, transmission, ABS, airbag, & multimedia, keep track of your car’s health, gauge the severity of problems, clear fault codes, and more.
Monitor live data
Live parameters or live data can help you take the guesswork out of understanding what your car needs and detect the fault origins.
Code and customize features
Access hidden features already set by the manufacturer and customize your car to fit your needs. This feature is only available on certain car brands/models, and the coding options vary.
Perform simple car maintenance independent of the workshop
Analyze emission and engine gauges, change and register your car battery, perform an oil reset, and much more, all with your smartphone.
Detect mileage manipulation
Car mileage manipulation is on the rise. Don’t get tricked. Use Carly to perform a used car inspection before buying.
Recent versions only work with the original Carly device.
I provide links to apk files that I do not test myself, these should be full versions, but sometimes this is not the case.
[Image: Carly-BMW-Pro-30.08.jpg]
Added a new version Carly Pro 46.18 All Car Brands
Thanks given by: Admin
Added a new version - Carly Pro 46.22 Full.
What's new:
- New codings for Audi, VW and BMW models 2007 - 2014
- New function for newer BMW models (starting roughly 2013): Engine Adaptation Reset
- Bugfixes for frozen Health checks
- Bugfixes for frozen application dashboard.
Thanks given by: Gh0sted10
Added a new version Carly All Car Brands 46.27.
Added a new version - Carly Pro 46.44 All Car Brands.
What's new:
Improved fault texts for newer VW, Audi, Seat & Skoda models (starting roughly 2014)
Coding for BMW G-models vastly improved: Video in motion, engine start stop memory added and much much more
Added a new version - Carly Pro 47.51 beta
Added a new version - Carly Pro 46.58
Added a new version - Carly Pro 46.63 + 50.04 beta
Added new version - Carly Pro 46.64. Whats new:
- All Carly brands in ONE app
- Fault information for BMW models between 2005 and 2020 improved with additional repair tips (only available for selective faults)
- Ford diagnostics now available as professional workshop level diagnostics! Carly will now show you the same error codes (incl. fault descriptions) as in a Ford workshop
- Improved fault texts and new parameter function for all supported Mercedes models
Added new version - Carly Pro 46.65
7 Guest(s)
