Latest news: ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ---- Zenzefi Aftersales Certificate 23.11.2026 Full ---- Diagbox 7.57 Files Complete Full ---- Man Mantis 12.2025 Full Activated ---- Mercedes WIS ASRA Standalone 10.2021 Activated ---- DTS 9.02 Keygen Patch FULL ---- DTS Monaco 8.16.015 Keygen Patch FULL ---- FoxFlash Offline Loader For KTM 200 Complete ---- DTS Monaco Projects Files Collection FULL ---- Smart 453 0.9 Turbo 66kw - need stage1 file ME17 9.20 ---- WinOLS 4.7 Native Installer + Complete Guide ---- Iveco Easy 18.1 Trucks + Buses + Keygen + Instruction ---- VCDS LASTEST VERSION FILES MEGA ---- ECM Titanium 40.000 Drivers Chip Tuning Firmware Editor ---- UPA SOFTWARE + SCRIPTS COLLECTION FULL ---- Ecu Connections All Cars Tool ---- DTS Monaco 9.02 + Patch + Keygen + Projects Full ---- Easy Kill v2.0 Start-Stop Off Tool ---- iDecoder 4.5 Ultimate Automotive ECU Immo Solution ---- ECU Repair Guide 2022 TOOL ---- Challenger TerraGator 3244 Service manual ---- JPRO 2026 v1.1 WITH ACTIVATION FULL ---- BMW ISTA Voltage Terminal Warning Disabler TOOL ---- PCR2.1 UNLOCKER TOOL FULL ---- IMMO Universal Decoding 3.5 Delete IMMO OFF ECU ---- BMW Easy Connect 2 v1.6 TOOL ---- Cmp Hex Tool Full ----
BimmerLink 2.36.2 + BimmerCode 4.28.4 + BTool v3.4.5 Expert + BimmerUtility 1.14.07
BMW
BimmerLink 2.36.2 + BimmerCode 4.28.4 + Bimmer BTool v3.4.5 Expert + 3.8.11 Lite + BimmerUtility 1.14.07 for BMW (Android apk) + BimmerInsight 2.2.3 for BMW (Android apk)
BimmerCode allows you to code the control units in your BMW or Mini to unlock hidden features and customize your car to your liking.
Activate the digital speed display in the instrument cluster or allow your passengers to watch videos while driving in the iDrive system. Do you want to disable the Auto Start/Stop function or the Active Sound Design? You will be able to code this and much more by yourself with the BimmerCode app.
!!! If you now install BimmerCode (new version), then NO version will work, the application (any version even 10 versions ago) works only for those who previously (on time) installed and updated the date from the server.This is the situation with the update date, it’s probably been a year now: a new hacked version comes out, everything works and is updated, after about a week the official developer blocks the update date.What to do? Wait for the new version to come out, install it immediately, update the date, and do not update (do not reinstall) unless absolutely necessary.
Supported cars
  • 1 Series 2008+
  • 2 Series, M2 2013+
  • 2 Series Active Tourer 2014+
  • 2 Series Gran Tourer 2015+
  • 3 Series, M3 2008+
  • 4 Series, M4 2013+
  • 5 Series, M5 2008+
  • 6 Series, M6 2008+
  • 7 Series 2008+
  • 8 Series 2018+
  • X1 2009+
  • X2 2018+
  • X3, X3 M 2010+
  • X4, X4 M 2014+
  • X5, X5 M 2008+
  • X6, X6 M 2008+
  • X7 2019+
  • Z4 2009+
  • i3 2013+
  • i8 2013+
  • Mini 2008+
  • Toyota Supra 2019+
[Image: BimmerCode.jpg]
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
Added new versions - BimmerLink 2.0.1, BimmerCode 3.2.0
Thanks given by: aminBen , aminBen , mthntm
Added new versions BimmerLink 2.0.4, BimmerCode 3.3.2 and a new program Bimmer BTool Expert 2.137
Thanks given by: pinupcasino777 , aminBen
Added a new version BimmerCode 3.3.3.
Thanks given by: aminBen , aminBen , Torzillas
Qingnan7780 Offline
BMW
password,please.I have press thanks and Rate (Reputation)
Added a new version BimmerCode 3.4.0.
Thanks given by: aminBen , aminBen , Torzillas , Torzillas , Nash21 , Nash21
Added a new version - BimmerLink 2.4.6
Added a new version - BimmerCode 3.5.0
Added a new version BimmerCode 3.7.0
Added new versions BimmerLink 2.18.2 + BimmerCode 3.9.0
