Latest news: ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ---- Volvo Tech Tool PTT 1.12 + Keygen Full ---- xDecoder 14.0 Launcher Package Fix ---- HP Tuners 5.1.1.198 + VCM Keygen FULL ---- SM3 Scanmatik Alpha4 PCMflash ---- JLR SDD ENGINEERING CALCULATOR TOOL ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ----
AlfaOBD 2.4.4.0 for PC + AlfaOBD 2.3.3 for Android
Alfa
AlfaOBD 2.4.4.0 for PC + AlfaOBD 2.3.3 for Android Patched
AlfaOBD is a software for the diagnostics of the vehicles produced by Fiat Chrysler Automobiles (FCA) group. Fiat / Alfa Romeo / Lancia, Chrysler / Dodge / Ram / Jeep. Although the software is primarily targeted for car owners, it provides many of the features of the professional scanners.
The software supported:
  • OBDLink
  • OBDKey
  • ELM327
  • Kiwi 3
  • K-Line USB interface.
AlfaOBD features include:
  • monitoring various dynamic parameters of the body, dash, code, engine, gearbox, ABS, climate control, etc. and graphical presentation as adjustable plots.
  • reading of static data: ECU id, system status, fault codes with probable causes and environment information where applicable.
  • clearing fault codes, monitoring the system for the appearance of new faults.
  • active diagnostics and configuration procedures for various equipment controlled by engine, gearbox, body computer, climate control, ABS, airbag, code control, other ECUs. Service light reset, engine oil change, DPF regeneration and many more.
  • electronic key and RF remote control programming.
[img]I provide links to apk files that I do not test myself, these should be full versions, but sometimes this is not the case.[/img]
Added a new version - AlfaOBD 2.1.9.6 (for Android) Patched
Added a new version - AlfaOBD 2.2.1.0 (for Android) Patched
Added new version AlfaOBD 2.2.5.0
Thanks given by: Kompel , Kompel , symace
Added new version AlfaOBD 2.3.5.0
(08-26-2022, 02:38 AM)raulinonog Wrote:
(06-24-2022, 07:49 PM)aleksey-ms Wrote: Adicionada nova versão AlfaOBD 2.3.5.0
Olá qual é a senha de descriptografia do download ????
Hello ! Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
Thanks given by: lindonato , ADMilstead , ADMilstead
Memoli Offline
(08-18-2020, 10:23 AM)aleksey-ms Wrote: Thank You !
Password please Smile
AlfaOBD 2.3.5.0 (for Android) Patched
  • OBDLink
  • OBDKey
  • ELM327
  • Kiwi 3
[Image: AlfaOBD.jpg] [Image: AlfaOBD-.jpg]
  • OBDLink
  • OBDKey
  • ELM327
  • Kiwi 3
Hello. Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
Thanks given by: fasda1984 , fasda1984
fasda1984 Offline
mega pass please??
yabec2005 Offline
thanks please pass
