Latest news: ---- Hyundai Heavy Equipment Factory Service Manuals ---- DAF XDC II 5.61 v95.00 + DEVKIT TOOL FULL ---- Truck Explorer Software Files Mega ---- scania sdp3 ---- Caterpillar Factory Password Keygen Full ---- Pump Diagnostics BOSСH VP44 VP30 Files ---- MITSUBISHI SEPE + MUT3-SE 2024.12 FULL ---- Mazda IDS v140 File MEGA ---- WABCO TEBS-E 7.00 LANG ENG FILES ---- JPRO CURRENT VERSION 2026 v1.2 FILES ---- FRM BMW DFLASH DATABASE FILES ---- BMW E-sys 3.8.1 + Patch And Keygen ---- Davinci Deluxe Edition 2025 v1.0.37 Full Token ---- XPROG 5.5.5 NO DONGLE NEED FULL ---- SCANIA SDP3 V2.70.1.3 FULL TRUCKS + MARINE + KEYGEN ---- BMW ISTA Updater GUI 2.0.0 TOOL ---- Bendix VCP ---- BMW Easy Connect ECC ISTA TOOL ---- VCM EDITOR COLLECTION FULL ---- VCDS Release 26.3.0 VIIPlus Loader 08.026.08 FULL ---- Winols 4.7 With Installer Full Mega ---- BMW CAS4+ EDITOR TOOL FULL ---- BMW ISTA 4.61.1x VERSION AND I-LEVEL OVERVIEW ---- ProSeCco Data Time Tool Full ---- CDA 6-J2534 bridge (Dubb45 Tool to use CDA with Passthru) ---- Subaru SSM4 Universal J2534 + Patch Full ---- Xentry Full Fix 4.9.8 Soft Easiest Installation Activation ---- Diagbox 7.57 Pack Complete Full ---- ODIS-S 26.0.1 + ODIS-E 22.0.0 + Fix Last Update ---- GM ECU FLASHER TOOL FULL ----
Scania#4: repair COO7_A2C30127800_Basic
minimex Offline
Hi,
in the attachment is what you need for repair COO7, dumps: MPC and two eeprom. All files come from unlocked device.
K-Tag programmer (v. 6.070) for MPC5554 (plugin 246) and any for AT25256 ( ".bin" file also for MPC).
In the set a description of how to connect a K-Tag with a COO7 pcb.
Changing balls under MPC is a different procedure,
you need station for removing and assembly of BGA, stencil, balls,  good flux and also manual skills, and you have to remove the varnish!
Good luck.
Thanks given by: gerikogan , iglowarez , Minias22 , CVE123
gerikogan Offline
password, please
