Latest news: ---- Injector Statics Dynamics Calculator Tool ---- WinOLS Organizer Automatic Tool ---- Bosch MD1CS TPROT Bypass Tool ---- BMW EDC16 EEPROM TOOL ---- Deutz-Fahr Tractors Factory Service Workshop Manuals ---- Ksuite 2.25 Clones Kess 5.017 Ktag 7.020 ---- ODIS Service 7.2.1 Multilang VAS5054A 6154 Passthru J2534 Win10 ---- HITACHI ALLINONE TOOL 3.9.0.0 MPDR 3.22 MEGA ---- VAG BMW MB OPEL PEUGEOT EDC17 FILES MEGA ---- Volvo Tech Tool Devtool License Editor Keygen Full ---- Fiat ecu map ---- SVEdit v1.1.38 ---- BMW E-SYS PSdZData Tool New Version Link MEGA ---- VEDIAMO PASSTHRU 5.1.1 + KG + PATCH ---- GM ECU FLASHER TOOL FIX ---- BMW CODING PACK FILES MEGA ---- iDecoder 4.5 No HWID Full ---- ECU Tuning Solutions 1.02 No HWID ---- VCDS HEX NET SUPPORT WIFI DOIP TOOL ---- BMW ETK Price 11.2026 ---- K-Suite Collection Professional Software Kess V2 K-TAG ---- GM GDS2 SOFTWARE + KEYGEN + PATCH ---- ECU Repair Guide Electronic Tool 2022 ---- BMW E-Sys 26.04.02 New Version MEGA ---- Best K-Suite Version For Kess 5.017 K-Tag 7.020 ---- Immo Doctor 2.1 + Multi Editor + DTC Off + Keygen ---- Subaru SSM3 Universal J2534 04.04 Patch Full ---- SCANIA SDP3 TRUCKS + MARINE + KEYGEN ---- CUMMINS INSITE 9.3.1-10.0-10.1 PATCH FIX TOOL ---- Iveco Power Trucks Buses 2020 Full MEGA ----
Remote Install - Caterpillar ET, SIS, HCIS, VIMS, CDVR, HIS, MCFE, Flash-Trim files
CAT
Remote Install - Caterpillar ET, SIS, HCIS, VIMS, CDVR, HIS, MCFE, Flash-Trim files, Schematics
CAT Schematics
CAT Articulated Dump Truck Full Models 03.2022 - Electric Hydraulic Schematics - $199
CAT Electric Rope Shovel Full Models 03.2022 - Electric Hydraulic Schematics - $899
CAT Engine Full Models 03.2022 Hydraulic Electric Schematics - $265
CAT Hydraulic Shovel Full Models 03.2022 - Electric Hydraulic Schematics - $1330
CAT Rotary Drill Full Models 03.2022 - Electric Hydraulic Schematics - $145
CAT Armored Face Conveyor Operation + Maintenance Manuals - $1390
CAT Scoop Operation + Maintenance Manuals - $555
CAT Electronic Technician ET 2024a (with keygen 1 PC locked) - $1150
CAT ET 2024c - $125
CAT ET 2024c (only activation) - $99
Caterpillar Electronic Technician ET 2019 - $69
Caterpillar Electronic Technician ET 2019 (only activation) - $45
Cat electronic technician is diagnostic software required to communicate, diagnose, and service electronically controlled Caterpillar engines and machines. When connected to an Electronic Control Module (ECM), a technician has the ability to diagnose existing and potential problems, configure the product and obtain data for analysis. This program works with the dealer diagnostic scanner Caterpillar Communication. The adapter as well as other adapters for diagnostics including scanner Nexiq.
Cat ET features:
  • Displays parameter status
  • Displays active diagnostics
  • Clear and View logged diagnostics
  • Performs Diagnostic tests
  • Print reports and diagnostic results
  • Perform calibrations
  • Displays current totals information i.e. fuel consumption, operating hours, etc.
  • Uploads new software (Flash Files) to ECM’s
  • Integration to help files
  • Creates engine warranty reports.
Caterpillar ET Factory Password Generator 18 digits - $455
Caterpillar ET Factory Password Generator 10 digits (for Win 10) - $25
CAT ET Factory Password 18 digits (just 1 time pass) - $95
How it woks: You paid -> send me html file -> then I'll send you back pass
Tokens for CAT ET Password Generator 18 digits - $20 (Price for 1 token)
The replacement credit/token you can submit a request when your USB Key reaches between 1 and 50 remaining tokens.
Keep in mind if you consume all tokens down to 0 your USB dongle will lock and will need to be mailed in to reload.
Caterpillar Component Based Troubleshooting CBT 2011B - $39
Caterpillar Engine Reprogramming Tool ERT - $55
The ERT application can flash specific ECUs and ACUs when the service tool (Electronic Technician) is not currently capable of ashing these specific devices. The ERT expects a type of flash file known as a DPK-file.
[Image: Caterpillar-ERT.jpg]
Caterpillar Service Information System (SIS)(with keygen) 2021 - $650
Caterpillar Service Information System (SIS) 10.2021 - $349
Caterpillar Service Information System (SIS) 2020 - $249
Caterpillar Service Information System (SIS) 2019 - $85
CAT SIS WEB 2.0 online subscription 3 months - $299
CAT SIS 2021 online (via remote desktop) 12 months - $135
CAT SIS 2021 online (via remote desktop) 3 months - $59
CAT SIS 2021 online (via remote desktop) 1 month - $35
Caterpillar SIS is the electronic service tool that Caterpillar dealers, customers, and employees rely on for their parts and service information needs. SIS provides information for all Caterpillar machines and engines from 1977.
[Image: Caterpillar-SIS.jpg]
Caterpillar Flash Files 2021 - $299
List of files
Caterpillar Flash Files 2020 - $99
List of files
Caterpillar Flash Files 2019 - $99
List of files
Caterpillar Flash Files 2004-2018 - $199
CAT Factory flash files for the Flash memory programming of onboard ECM. For this purpose, you need the latest activated version of the Caterpillar Electronic Technician application and the genuine Cat Diagnostic Adapter Interface to connect with the vehicle.
CAT FLS - DTC Map/OFF Module (1 year subscription) - $990
Generate detailed DTC maps in CSV format ready for import to OLS, Create binary DTC OFF file with a few clicks.
CAT FLS Converter Tool - $599
Simplify the conversion of FLS files to RAW Binary format and vice versa.
Seamlessly convert modified Binary files back to FLS with checksum for hassle-free flashing using ET, also you can change FLS file description or part number.
[Image: CAT-FLS-Converter-Tool.jpg]
Caterpillar Customer Password Recovery - $39
[Image: Caterpillar-Customer-Password-Recovery.jpg]
Caterpillar Hose, Coupling Information System (HCIS) - $55
Caterpillar specializes in manufacturing high-quality hydraulic hoses and couplings for the sector equipment manufacturers and the overall market. Caterpillar has continued to expand production around the world in order to strengthen its position as a leading manufacturer of hydraulic hoses, couplings, and steel complex knots.
Caterpillar range includes a variety of different configurations of hoses and couplings, from small to large diameter hoses. Created by Caterpillar coupling under high-pressure hydraulic hoses and package units sold under the trade names Cat.
This website contains information system Caterpillar Hose & Coupling Information System (HCIS) contains complete documentation for the selection of hoses and couplings products Caterpillar.
[Image: Caterpillar-HCIS.jpg]
Caterpillar Vital Information Management System (VIMS) - $55
Caterpillar's Vital Information Management System (VIMS) is a powerful tool for machine management that provides operators, service personnel, and managers information on a wide range of vital machine functions. Numerous sensors are integrated into the vehicle design.
[Image: Caterpillar-VIMS.jpg]
Caterpillar Digital Voltage Regulator (CDVR) - $35
The Cat Digital Voltage Regulator is a microprocessor-based control designed to provide precise voltage control, robust transient response, and generator protection with industry-leading features and versatility.
CAT CDRV features:
  • Microprocessor-based control featuring a choice of three control modes standard:
  1. Automatic Voltage Regulation (AVR)
  2. Power Factor Regulation (PF)
  3. Reactive Power Regulation (Var)
  • Programmable stability settings
  • Soft start control with an adjustable time setting in AVR control mode
  • Dual Slope Underfrequency (volts/hertz) regulation
  • Three-phase or single-phase generator voltage (RMS) sensing/regulation in AVR mode
  • Single-phase generator current sensing for regulation purposes
  • Field current and field voltage sensing
  • Five contact sensing inputs for system interface
  • One common LED for visual indication of Alarm and Shutdown fault conditions
  • Fault Shutdown Driver and Alarm Output Driver for an indication of Alarm and Shutdown fault conditions
  • Generator paralleling with reactive droop compensation and reactive differential compensation
  • Line drop compensation
  • Remote communication interface via CAN 2.0B
  • Ten generator protective functions.
[Image: Caterpillar-CDVR.jpg]
Caterpillar Hydraulic Information System (HIS) - $39
It is an original spare parts catalog, presents Hose & Coupling, Cylinder & Seals, Pumps & Motors, Seals, Valves.
[Image: Caterpillar-HIS.jpg]
Caterpillar Forklift MCFE 10.2024 + Workshop Manual - $555
Caterpillar Forklift MCFA 10.2024 - $315
Caterpillar Forklift MCFS 10.2024 - $315
Cat Lift Trucks is an electronic catalog that contains detailed information on spare parts and accessories, special instructions, spare parts management, parts books and any additional information for forklift trucks Tracked MCFA the Latino market. Parts manual contains accurate product and helps identify potential problems and to carry out maintenance on problem areas and equipment failure information. The catalog interface is elementary and convenient, allows you to search for parts and accessories.
[Image: Caterpillar-MCFE.jpg]
Also here CAT diagnostic adapter
Caterpillar 426C Backhoe Loader Service Repair Manual - $99
Caterpillar Backhoe Loader Full Models Electric Hydraulic Schematics 1988-2021 - $199
CAT Paving Compactor Full Models Electric Hydraulic Schematics EN 2022 - $250
[Image: CAT-Piving-Diagrams.jpg]
Caterpillar delete DPF, ARD for C7S C9S C13 LEEC15 SDP - $775
DPF delete and ARD delete with step by step instructions and Flash files.
Caterpillar Technician Training - $99
What's inside:
ACERT Technology for On-Highway Engines, ACERT Technology for On-Highway Heavy Duty Engines, Diesel engines - family 3600, Electrics, Engine, Engine Diagnostics, Fuel System, HVAC, Hydraulics, Machine Hydraulics, Powertrain, Programming, Tools, Engine controls 3406E, Engine controls 3408E, 3412E, Engine electronics, EUI Fuel system, HEUI, HI300B Fuel systems, Off-highway trucks 773F (EED), 775F (DLS), Vocational Truck, On-highway truck transmission.
Caterpillar Injector Trim Files 9000 files 2020 update $115
Need it? Write to me to discuss.
There is a new price for - CAT SIS 2020.
Added - Caterpillar Flash Files 2020
Added a new version - Caterpillar MCFA/E/S 2020.
Added CAT ET 2020a (with keygen 1 PC locked)
Added a new version - CAT ET 2021
Diesel288 Offline
HELLO DEAR
I NEED INFO POR TRIM FLASH CAT
Added a new version - Caterpillar Service Information System (SIS) 2021
Added - Caterpillar Flash Files 2021
Added CAT SIS 2021 online (via remote desktop) 12 / 3 / 1 months
