The DASH-Book program is a reference tool necessary for quick removal and disassembly of the instrument cluster, the program describes the step-by-step process of removing the instrument cluster from the car, analyzing the instrument cluster, memory location, memory type, connecting the instrument cluster voltage to check odometer readings , in-circuit programming points, memory dumps with different mileage.
The SRS-Book program is a reference tool necessary for quick removal and disassembly of the SRS airbag control unit, the program step-by-step illustrates the process of removing the SRS airbag control unit from a car, disassembling the SRS airbag control unit, memory location, memory type , connection diagram of the SRS airbag control unit, in-circuit programming points, memory dumps with CRASH and CLEAR for various modifications of the SRS airbag control unit.
I recommend OS WinXP, Win7, Win8
In the folder there is a ID generator, run get hardware ID, write me your ID
The resulting license file throws in the root of the folder DASH-Book v7.9 and SRC-Book v1.4 and immediately can be launch.
