Latest news: ---- PCM Flash Dongle Manager TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Link MEGA ---- I have an original Delphi diagnostic ---- John Deere Advistore 5.4.44 ag+cf 2025/07 ---- SIM3K543-E2 ECU Catalyst Off Calibration TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Engineering PET2 PCM FULL ---- XENTRY XUS DAS WIS EPC STARFINDER VEDIAMO MONACO 09.2026 ---- WinOLS File Unlocker Stage Extractor Tool ---- PROGRAM ECU TUNING SOLUTION 1.02 FREE FOR ALL ---- MAGIC TUNERS PACK + KEYGEN FULL ---- PROGRAM ECU TUNING SOLUTION 1.01 FREE FOR ALL ---- PETKA 8.9 FILES + VIN SEARCH FULL ---- MTX DTC REMOVER 1.8.5.0 + KEYGEN FULL ---- AlfaOBD PC Version PRO + Lic Generator ---- VCDS 26.9.0 LAST VERSION + LOADER FULL ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ----
Can Clip RTL2002 Full Pack (Renault/Dacia)
lfas Offline
Renult
Can Clip Full Pack  Remote installation
_ Can Clip 230 (2023) Activation till 2029
_ Dialogys French  2021
                 English 05.2018
                 German  05.2018
                 Russe  09.2018
_ Reprog 191 ( 11.2020 )
_ Pin Extractor 2
_ Pin Extractor 2.6
_ Radio Pre-code
Price 50$
___________________________________________________________________________________________________________________
Note for this install:
( Clip v214 Release 04.2022 is the final version for offline programming )
( Clip v200 Release 2021 is the final version for coding/configuration )
For old CLIP RTL2002, I install v214 with a Full pack for programming, and v200 on another laptop for coding, v200 needs +15$
if you need RenoLink 2.0.7  & EAsy Renault 6.4: Link Here
[Image: 21012201535325315417224628.png]
DDT2000 12/2019 for VCI USB-DIAG 3*
price = 40€
info
DDT2000 is complexe and can make a lot (maybe everything) but it's for really skilful people that they know what they do because its also really dangerous as you can fire airbags, erase ECU...
and it uses an expensive interface, so ddt2000 will be useless for someone without the skills and the needs, it is more for studying than operate on cars.
renolink is a soft that use the ddt2000 command to do job but really simplified with cheap interface hardware (obdlink SX)
[Image: 20072709434725315416938258.jpg]
[Image: 20072709434725315416938259.jpg]
Regards
lfas Offline
Updated / 06.2020
lfas Offline
(07-10-2020, 05:40 AM)lfas Wrote: Updated / 06.2020
Updated  / 11.2020
lfas Offline
Updated  / 02.2020
