Autocom and Delphi 2017.01 V3 + Activation
lotfi Offline
Base - 2017.01 of well-known guy...
Fixes and news with V3 release (11.05.2020):
- new V3 Bluetooth connection bug fix (hex2stuff bug). Now should work perfectly!
- connection with modules fixes (database fixes). A lot of modules connection is now reachable without issues!
- new maps and codding guides (update for new cars)
- other minor changes.
- new keygen funcionality (installation.xml files generator). Keygen (without license) included into the package.
- small fix for Windows 10 (random activation loss after PC restart). Maybe it will work for someone who facing with this issue.
This should be now the best 2017.01 solution so far!  [Image: muscle.gif]
Mods:
 - new splash and icons (from 2020 release)
- cosmetic change of the main interface
- Delphi version
[Image: 01.png]
[Image: 02.png]
[Image: d1.png]
[Image: d2.png]
Activation: Only 1 free activations (cars or trucks) per user for V3 release.
Please post Your FileActivation.xml file here (rename it with Your user name, for example: "user1.xml"). No need for other information like cars trucks etc.
Just upload Your renamed activation file.
Rate + Thanks = Activation
gerikogan Offline
Hi
For a five or six digit device?
lotfi Offline
(05-24-2020, 03:09 PM)eddieddi Wrote: Hi, Activation please
Autocom cars
THX
THIS IS U ACTIVATION CARS 2017 SIR.
(05-24-2020, 06:11 PM)hocek Wrote: Szia, aktiválás kérem
THIS IS YOUR ACTIVATION
Thanks given by: eddieddi , Admin , Prodrive , dragand
weedi Offline
Audi
Activation Please Delphi Cars
(05-25-2020, 05:20 PM)weedi Wrote: Activation Please Delphi Cars
Thanks given by: valtimjr
lotfi Offline
please Rate + Thanks = Activation
RATE + THANKS = ACTIVATION
Thanks given by: Admin , Hubro2
lotfi Offline
NO RATE AND NO THANKS = NO ACTIVATION
IF YOU WOULD LIKE ACTIVATION PLEASE DO LIKE AND THANKS
Thanks given by: Aviatorn
ivo321 Offline
 Thank you for activation.
gerikogan Offline
activation DELPHI
thank
gerikogan Offline
Thank you brother.
I installed and activated. All OK.
But I have a device with a five-digit serial number.
And your program for a six-digit device.
And thanks anyway for activation!
google translate
lotfi Offline
(06-12-2020, 10:15 AM)ivo321 Wrote:  Thank you for activation.
This is u activation sir.
