improvement Ktag clone
reda Offline
Windows
as attachment a photo of the ktag card, the components to change are identified, we replace the Chinese entry-level capacitors, filters and transistors of good quality.
There is also the list of components with ref and price from RS
working time: 2h
flow of good quality, braid, solder, hot air station and correct iron needed.
It's small, we change CMS so we need good eyes and do not shake.
Admin Online
Owner
Forum Rules - MANDATORY DO NOT SKIP
01: The only language spoken/written on this forum is English.
http://automotiveforum.net/showthread.php?tid=6
Thanks given by: reda , nedved59
Orchid70 Offline
Wow - Nice!!
