Latest news: ---- PCM Flash Dongle Manager TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Link MEGA ---- I have an original Delphi diagnostic ---- John Deere Advistore 5.4.44 ag+cf 2025/07 ---- SIM3K543-E2 ECU Catalyst Off Calibration TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Engineering PET2 PCM FULL ---- XENTRY XUS DAS WIS EPC STARFINDER VEDIAMO MONACO 09.2026 ---- WinOLS File Unlocker Stage Extractor Tool ---- PROGRAM ECU TUNING SOLUTION 1.02 FREE FOR ALL ---- MAGIC TUNERS PACK + KEYGEN FULL ---- PROGRAM ECU TUNING SOLUTION 1.01 FREE FOR ALL ---- PETKA 8.9 FILES + VIN SEARCH FULL ---- MTX DTC REMOVER 1.8.5.0 + KEYGEN FULL ---- AlfaOBD PC Version PRO + Lic Generator ---- VCDS 26.9.0 LAST VERSION + LOADER FULL ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ----
Renault Clio III 2007 SID304 Virgin
sinan1994 Offline
Hi Guys i need your help.
I have Clio 3 from 2007 with 1.5 dci diesel engine. car was running we change the ups in the front. car was not running after replace the ups modul.
after i try to fix it with renolink. in this moment i confuse it with uch and renewe it. (big shit). so i lost isk code but pin read it with autel. so i try write a dump from internet on uch and try to sync it with ecu but no result. i try to virgin the ecu with obdstar but no sucsess to learn it with autel im608. autel sad ecu is not blank. who can help me ? or give me a tip for a solution?
maybe somone can fix the uch eeprom
i send uch eeprom and flash from ecu sid304
fin: VF1BR2C0638434070
Pin Code is :A219B915AA6C
ISK : ?????
Thanks given by: delyan
roque Offline
I can help u find ISK, we need algo, if u still interested, write to me.
