Latest news: ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ---- Zenzefi Aftersales Certificate 23.11.2026 Full ---- Diagbox 7.57 Files Complete Full ---- Man Mantis 12.2025 Full Activated ---- Mercedes WIS ASRA Standalone 10.2021 Activated ---- DTS 9.02 Keygen Patch FULL ---- DTS Monaco 8.16.015 Keygen Patch FULL ---- FoxFlash Offline Loader For KTM 200 Complete ---- DTS Monaco Projects Files Collection FULL ---- Smart 453 0.9 Turbo 66kw - need stage1 file ME17 9.20 ---- WinOLS 4.7 Native Installer + Complete Guide ---- Iveco Easy 18.1 Trucks + Buses + Keygen + Instruction ---- VCDS LASTEST VERSION FILES MEGA ---- ECM Titanium 40.000 Drivers Chip Tuning Firmware Editor ---- UPA SOFTWARE + SCRIPTS COLLECTION FULL ---- Ecu Connections All Cars Tool ---- DTS Monaco 9.02 + Patch + Keygen + Projects Full ---- Easy Kill v2.0 Start-Stop Off Tool ---- iDecoder 4.5 Ultimate Automotive ECU Immo Solution ---- ECU Repair Guide 2022 TOOL ---- Challenger TerraGator 3244 Service manual ---- JPRO 2026 v1.1 WITH ACTIVATION FULL ---- BMW ISTA Voltage Terminal Warning Disabler TOOL ---- PCR2.1 UNLOCKER TOOL FULL ---- IMMO Universal Decoding 3.5 Delete IMMO OFF ECU ---- BMW Easy Connect 2 v1.6 TOOL ---- Cmp Hex Tool Full ----
HPT Editors v2026 (Convert BIN to HPT/to BIN & Unlock Files)
lfas Online
Actia
[Image: HPT-EDITORS-2026-1024x682.jpeg]
HPT File Editors 2026 Pack, 3 Offline Tools:
Price 120$
The license is linked to the laptop; you can change the SSD or reinstall Windows when needed.
HPT to BIN Converter tool that supports the newest version of HPT Files v5.3…>
1. Hoppers Edition Converter
2. MMOQRY Edition Converter  (+ HPT Lock Remover)
Functions:
Convert HPT to BIN
Convert BIN to HPT
Unlock HPT Files
Quick view and change of key file identifiers
(VIN, OS/Base ID, ECM serial, Interface ID)
Convert files from old to new versions, and from new versions to old versions.
Segment Swap, and use the built-in hex editor for advanced inspection.
[Image: HPT-Editor-2026-HOPPERS-1024x771.png][Image: HPT-Editor-2026-HOPPERS-2-1024x770.png]
[Image: HPT-Editor-2026-MMOQRY-1024x777.png][Image: HPT-Editor-2026-MMOQRY-2-1024x765.png]
[Image: HPT_Tuner_Lock_Remover.png]
New HPT File Editor 2026 v4 Online
Price 220$
Guaranteed for 1 year (Partial refund if the software stops)
HPT File Editor 2026 is a lightweight Windows utility built to work with the new HPT files read in VCM Suite 5.3...
Quickly view key file identifiers (VIN, OS/Base ID, ECM serial, Interface ID),
convert HPT ↔ BIN & BIN ↔ HPT,
unlock HPT Files, CTZ ↔ HPT & HPT ↔ CTZ,
+ XDF Maker & ECU Patcher
[color=#ffffff].
Full Description:
Open and analyze .hpt files: segments, OS IDs, VIN, vehicle identifiers
Full hex editor with find/replace (hex or ASCII)
Convert HPT format versions, unlock compatible files, rebuild and save
Send files to PAT dev support directly from the app
Supports HPT custom OS IDs (69-prefix) with automatic OEM catalog mapping
CONVERT — HPT, BIN, CTZ & EFI workflows
  • BIN ↔ HPT import/export (full BIN or per-segment)
  • CTZ → BIN / CTZ → HPT (including locked/encrypted CTZ)
  • HPT → EFI Live BIN for L5P, LML, E86A, T87, T87A, A50
  • CM2450 Cummins round-trip with separate 16-byte header file
  • E41/A50/T87A sidecar support for valid EFI checksum output
  • Built-in E86A EFI padding for 11–14 LML conversions
SEGMENTS — Segment swap
  • Copy selected segments from a donor HPT into a target HPT
  • Ideal for transplanting cal sections between compatible files
SEARCH & SORT — Manage large tune libraries
  • Folder Search — find .hpt/.ctz by OS, make, year, name, cal name
  • OS Sorter — batch organize files into nested folders (OS / Year / Make)
  • Copy or move modes with progress tracking
ECU UNLOCK — GPEC family
  • Unlock GPEC2, GPEC2A, GPEC4, and ECO-Diesel calibration BINs
  • Secure online unlock via PAT API with offline fallback
XDF MAKER — Definition downloads (credit-based)
  • Register/login with shared PAT account
  • Browse and download XDF definitions matched to your file’s OS ID
  • Re-downloads of owned XDFs are free
  • Works with OEM and 69-prefix custom OS IDs
BIN PATCHER — One-click server patching (credit-based)
  • Load stock HPT → select patch variant → receive patched HPT automatically
  • Server applies patch, fixes checksums, and rebuilds your file
  • DEF-reset bundle support on supported CAL IDs (base + DEF outputs in one run)
  • Patch catalog updates from PAT servers — no manual patch files to manage
STOCK FILES — Online calibration library
  • Search and download stock .hpt, .ctz, .bin, and .vbf files from the PAT library
  • Filter by make, module, OS, model, keyword, and more
TOOLS — Built-in utilities
  • Ford VBF → BIN (LZSS decompression)
  • Cummins XCAL/HEX → BIN (CM24xx / CM2350B)
  • ECFG2XDF (Beta) — Cummins ECFG to TunerPro/HP Tuners XDF
  • J1939 DTC Converter
  • VIN2HEX / ASCII utilities
  • Checksum calculators (LSuite PAT-themed + Delco support)
For more detials in the Offical Page & for FEEDBACK & SUPPORT:
https://performanceautotechnologies.com/...itor-2026/
[Image: NewHPT-Editor-3.8.1-CTZ-1024x487.png]
[Image: NewHPT-Editor-3.8.1-CTZ-HOME-1024x667.png]
Thanks given by: emre00007 , CHRISSAT , marjan47 , marjan47 , Admin , Admin
Waymaker Offline
looking to get this
