Latest news: ---- Seed Key 3.0 Calculator DTS Monaco Vediamo Tool ---- BMW ISTA-PLUS 4.62.11 Programming FULL ---- Alfa Romeo Stelvio Workshop Repair Manual ---- Hex Editor Tool Full ---- BMW ISTA 4.62.1x I-LEVEL OVERVIEW FULL ---- IVECO Power Trucks Buses EPC 2024 Full MEGA ---- IDA PRO 9.4 + KEYGEN FULL ---- PCM Flash Dongle Manager TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Link MEGA ---- I have an original Delphi diagnostic ---- John Deere Advistore 5.4.44 ag+cf 2025/07 ---- SIM3K543-E2 ECU Catalyst Off Calibration TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Engineering PET2 PCM FULL ---- XENTRY XUS DAS WIS EPC STARFINDER VEDIAMO MONACO 09.2026 ---- WinOLS File Unlocker Stage Extractor Tool ---- PROGRAM ECU TUNING SOLUTION 1.02 FREE FOR ALL ---- MAGIC TUNERS PACK + KEYGEN FULL ---- PROGRAM ECU TUNING SOLUTION 1.01 FREE FOR ALL ---- PETKA 8.9 FILES + VIN SEARCH FULL ---- MTX DTC REMOVER 1.8.5.0 + KEYGEN FULL ---- AlfaOBD PC Version PRO + Lic Generator ---- VCDS 26.9.0 LAST VERSION + LOADER FULL ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ----
Help Iveco easy 16.1 e 18.1
Renatoone95 Offline
Iveco
Good afternoon friends, does anyone know why and how to fix the message "you do not have the necessary permission to use this type of function: basic diagnosis" in the Iveco easy 16.1 and 18.1 program?
Thanks given by: talharafique , teejay
Irfan796 Offline
what is the process of activation that you use? try to activate with ec-0000--00000 instead of eci serial
Renatoone95 Offline
(09-22-2025, 09:00 AM)Irfan796 Wrote: what is the process of activation that you use? try to activate with ec-0000--00000 instead of eci serial
Code:
1-Install the Iveco Easy program.
2-Install the Java environment for your operating system @free from the internet@
3-Run Keygen1.exe
Click: Read current and OK
Click: Generate new and OK
 4-Open E.a.sy on the desktop and close.
5-Run Keygen2.exe @this requires a Java environment@
Set the expiration date
 Select all DVDs
 Set the ECI number. EXAMPLE: EC-01009-04-05-04 c) Click: All
 Click: Get
 After that, you will get the easy_all.txt file in the root of Keygen2.exe.
 Rename: easy_all.txt to actCodes.txt
6-Create a new file ECIs.txt and write your ECI number.  EXAMPLE: EC-01009-04-05-04 f)
7-Copy actCodes.txt + ECIs.txt for Windows XP and Windows 7: C:\Program Files\Eltrac\EASY\Db\Perms
8-Copy the files and folder in the Perms folder (pSets, pSetsNet, rSets, rSetsNet, actCodes.txt, ACIs.txt) replace to
   Windows XP: C:\Documents and Settings\All Users\Application Data\Iveco\Easy\Perms Windows
   windows7: C:\ProgramDATA\Iveco\Easy\Perms
Thanks given by: hobortos , hera26 , CatsEye , stuchan , mosesik , Armindo
Irfan796 Offline
Click: Get
this is wrong. eci number should be EC-00000-00-00-00
Click: Get
feel free to contact me through pm for contact info if you still need help, and I will help you via teamviewer
Renatoone95 Offline
Okay, I'll check when I have an answer and I'll let you know here.
Thanks given by: ivo53 , makulis
s813no Offline
(09-24-2025, 01:32 AM)Renatoone95 Wrote: Okay, I'll check when I have an answer and I'll let you know here.
renatone devi aver sbagliato il copia-incolla dei file
Thanks given by: marj , willi5 , noxpire , omdx24 , malozlo2 , Johnbework
Renatoone95 Offline
It worked, friend, with a zero ID the VCI worked.
(09-23-2025, 01:12 PM)Irfan796 Wrote: Defina o número ECI. EXEMPLO: EC-01009-04-05-04 c) Clique: Todos
Clique: Obtenha
isso está errado. O número ECI deve ser EC-00000-00-00-00
Clique: Obter
isto está errado. O número ECI deve ser EC-00000-00-00-00
Sinta-se à vontade para entrar em contato comigo por mensagem privada para obter informações de contato se você ainda precisar de ajuda, e eu o ajudarei através do TeamViewer
(09-26-2025, 10:29 PM)Renatoone95 Wrote: Deu certo, amigo, com ID zero o VCI funcionou.
Thanks given by: octarm2112
yanglf Offline
(09-23-2025, 01:12 PM)Irfan796 Wrote: Set the ECI number. EXAMPLE: EC-01009-04-05-04 c) Click: All
Click: Get
Click: Get
i tried to activate using  EC-00000-00-00-00  while generating actCodes.txt and ecis.txt  set  EC-00000-00-00-00
it shows an error no ecu data available
