Latest news: ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ----
Jeep - Chrysler - Dodge IMMO Tools (APNT + AEMT-Maxx + Chysler v3)
lfas Online
Jeep
AEMT-MAXX IMMO Tool J2534 (2005/2022)
AEMT MAXX official website:
Cost 90$ AEMT MAXX is a tool that evolved from an early SKIM and VIN tool developed by ECUunlock.
The tool allowed the user to make a SKIM-activated PCM into a SKIM-desactivated PCM.
_Supported ECU Types From 1995 to 2008 Model.
SCI ECU, JTEC, SBEC, NGC1, NGC2, NGC3, CUMMINS
Disable SKIM: IMMO OFF
SRI Mileage Edit: Modify the Service Reminder Indicator mileage.
VIN Editor: Edit Vehicle Identification Numbers.
Read Memory: Access and read flash memory.
Write Memory: Write data back to the flash memory.
_ Supported CAN BUS Systems From 2005 to 2021 Models.
NGC3, NGC4, NGC4A, GPEC, GPEC2, GPEC2A, GPEC3, CUMMINS
Read EPROM: Read data from EPROM.
Write EPROM: Write data back to EPROM.
Write Memory: Write flash memory data efficiently.
_______________________
APNT Chrysler IMMO OFF J2534 (2005/2019)
Cost 60$, use it with J2534 devices,
to edit the SKIM security and VIN change.
APNT functions: (chrysler-dodge-jeep)
- READ ECU INFO
- SKIM DISABLE
- SRI MILEAGE EDIT
- VIN EDITOR
** for gas ecu's 1995-2019
** for diesel from 1998 -2013
list supported ecu's:
( siemans and cummins ecu's support vin read and write only )
make sure your j2534 device supports sci ( j2610 ) and can bus before purchase
apnt is benchtop programming tool.
(most use it in vehicle with no issues. i can not guarantee it supports all in vehicle programming )
apnt will disable skim but!!! if you install ecu into a vehicle with a skim module it will re-enable skim in that vehicle . you will need to unplug skim module if you are using for this purpose.
Be careful:
if you unplug the skim module to disable skim you will lose keyless entry and tire pressure monitor functionality.
To Watch APNT VIDEO, Click Here
Chrysler Tool v3.0 for VIN change, Cost 30$
Antena Vatansever, Kalibre (24lc16)
Anten Cherokee (MCU 9S12DB128 eeprom)
RFH V1 Joumey 2011+, Şarj Cihazı, 300M (MCU 9S12EXQ384 eeprom)
TIPGW Cherokee (MCU 9S12DT256 eeprom)
Compu Motorola V1'in hafızası var (95320)
Compu Motorola Memoria 195080)
Compu Motorola Memoria 2(95080)
RFH V2 Grand Cherokee, Durango (MCU 9S12EXQ384 eeprom)
RFH V3 Pusula (MCU 9S12EXQ384 eeprom)
RFH V4 Dart (MCU 9S12EXQ384 eeprom)
RFH V5 2017+ (95640)
Bilgisayar Motorola V2 hafızalı (95320)
BCM RAM SPC5606B (D-FLAŞ)
[Image: Chrysler-IMMO-Off-v3.0.png]
Price for the 3 software is only 120$ if it's needed.
B.REGRADS
Thanks given by: jgdf
Jem@prog Online
(06-13-2025, 05:01 PM)lfas Wrote: AEMT-MAXX IMMO Tool J2534 (2005/2022)
- READ ECU INFO
- SKIM DISABLE
- SRI MILEAGE EDIT
- VIN EDITOR
Be careful:
B.REGRADS
Hello is this available please
autorepair Online
i have the newest one ecu villan 2.0 if intrested pm me
Jem@prog Online
(12-17-2025, 11:15 PM)autorepair Wrote: i have the newest one ecu villan 2.0 if intrested pm me
Can it turn off Skim in a NGC3 2006 Dodge Dakota?
