Latest news: ---- Hino DX3 v1.25.1 Diagnostic Solution Files Mega ---- Winols EDC15 Mappack Generator TOOL ---- xDecoder + Keygen 100% Work ---- VAG PCR 2.1 DECODER TOOL FULL ---- SDD use for LR Discovery 4 ---- Toyota Lexus GTS+ 2026 Offline Diagnostic Software ---- ECU Tuning Solutions + Keygen IMMO DTC EGR DPF ADblue OFF ---- BMW PSdZData 4.61.11 Torrent File FULL ---- BMW ISTA+ 4.60.30 Standalone Files FULL ---- GM GLOBAL B SEED KEY CALCULATOR ---- BMW ISTA Standalone 4.61.12 FULL MEGA ---- CAT SIS 01.2018 TORRENT FILE FULL ---- BMW ISTA GUI 1.4.6 TOOL FULL ---- BMW ISTA Czech Database 4.57.XX 4.61.XX MEGA ---- BMW ISTA+ 4.61.1x Files MEGA ---- BMW ISPI ISTA LAUNCHER 1.61.02.2059 MEGA ---- DASH CALCULATOR TOOL FULL ---- Fiat MultiEcuscan 5.3 - 2024 ---- ISUZU SERVICE REPAIR MANUAL PACKAGE ---- Odis-S 25.3.0 + Odis-E 21.0.1 Full 08.2026 ---- XENTRY 09.2026 RELEASE 4 FILES ---- Can Clip 221 Tactrix OpenPort PassThru + Keygen Full ---- CAS-2 Editor 3.1 Tool FULL ---- PORSCHE ENGINE 2.9 BITURBO WIRING DIAGRAM ---- MB 7G.SCN Coding Data Collection Offline Programming ---- PCM Flash Dongle Drivers J2534 FULL ---- All Cars Pin Diagram Tool Full ---- Hello, let me introduce myself. ---- Hello ---- Inpa64 Tool64 Update Ediabas 7.7.2 Full ----
Service Ranger 4.9 with keygen or activator
Savior2064 Offline
Does anyone have a copy of Service Ranger 4.9 that they can share struggling with 4.2 not able to activate due to it stating cant register because of no internet connection. Would be much appreciated.
MizteriouzA Offline
(05-29-2025, 02:34 AM)Savior2064 Wrote: Does anyone have a copy of Service Ranger 4.9 that they can share struggling with 4.2 not able to activate due to it stating cant register because of no internet connection. Would be much appreciated.
Hello there friend,
I was having issues with service ranger 4.2 as well until I found out there is 2 different versions out there on the internet. How I ended up fixing it was using the install from the version where that replacement files didn't work (possibly the one you have) and then used the replacement files from the 2nd version and that worked! Can also confirm that it works on windows 10 but you need to run the keygen in a windows 7 computer. If I can be of any help let me know and if you get a working 4.9 version and want to share let me know as well Smile
Savior2064 Offline
Hello there friend,
I'll try that out. I believe I have both 4.2 versions. Appreciate your help. I'll let you know if I get a working version of 4.9. And yes I'm using win 7 to generate the SN codes
Savior2064 Offline
Tried that still no success. Any other suggestions.
