Latest news: ---- PCMflash 1.2.0 - 1.2.1 Dongle Security TOOL ---- DTSProjects for DTS 9.04.016 ---- DTS 9.04.016 FULL PATCH ---- GM TIS2000 NAO Virtual Machine New Update ---- DRB III Emulator Virtual Machine New Update ---- Bosch ECU Database v0.3 Tool ---- ZenZefi After Sales Standard Valid Until 2027.02.17 ---- EDC17 IMMO SERVICE TOOL ---- Davinci Deluxe 1.0.XX.0 Full ---- MULTI EDITOR BY DR SALEH FULL ---- Zenzefi Aftersales Certificate 17.02.2027 + 26.11.2026 ---- Lsuite Checksum Tool Full ---- Kubota Service Manuals (FSM) Collection ---- DTS Monaco 8.16.015 Install + Patch + Keygen FULL ---- Multi Editor Honda 1.39.1.0.0 Full ---- Clone OpenPort 2.0 Windows 11 Driver ---- FTAG Checksums Test Fix TOOL ---- DTS Monaco 9.02 Install + Patch + Keygen FULL ---- PCMflash Dongle Manager 0.1.2 China Dongle Emulator ---- Zenzefi Aftersales Certificate 17.02.2027 ---- IMMO SERVICE TOOL 1.2 + INSTRUCTION FULL ---- Renault Can Clip 222 RTL2002 + Patch Full ---- Xentry Cars Passthru OpenShell 09.2026 Xus Das Wis Epc Starfinder Vediamo Monaco ---- VAG IMMO OFF TOOL NEW UPDATE ---- PCMflash Dongle Manager New Update ---- BMW Voltage Monitor TOOL ---- Global TechStream GTS+ Software ---- Seed Key 3.0 Calculator DTS Monaco Vediamo Tool ---- BMW ISTA-PLUS 4.62.11 Programming FULL ---- Alfa Romeo Stelvio Workshop Repair Manual ----
DaVinci Deluxe Offline Edition (04.2025)
lfas Online
PLEASE REMEMBER TO USE ONLY THE ORIGINAL FILES,
DO NOT USE MODIFIED OR PARTIAL READ FILES
(will show the message "not supported")
PRICE:
40$ Unlocked Software
[Image: DAVINCI-1.0.34-1024x591.jpg]
Davinci for the EGR/DPF/DTC Remover includes all the tools that a workshop needs
to diagnose and correct problems related to modern antipollution systems, such as:
DPF (Diesel Particulate Filter)
EGR (Exhaust Gas Recirculation),
SCR (Selective Catalyst Reduction)
TVA (Throttle Valve Actuator)
MAF (Mass Air Flow)
LAMBDA (O2 Sensor)
FLAPS (Manifold Swirl Valves)
READINESS (OBD Readiness Protection)
START & STOP
NOX (Nitrogen Oxides Sensor)
LIMP (Fail Safe Mode)
AGS (Active Grill Shutter)
DTC (Diagnostic Trouble Code)
The DTC function scans and names all codes present in the calibration file, listing them for the user to select and remove with just one click.
For advanced users, there is an option to export the DTC tables in ASAP2 Format to later load them into third-party software that supports ASAP2 standards. Additionally, it is possible to load a custom DTC list from the menu files.
________________________________
Hello, sorry but this tool is not 100% working as the genuine Davinci.
The tools have some bugs. For example, the DTC Remover is working well with all modules, but the DPF & EGR...etc, have bugs with many modules...
Here is some feedback for some TESTED Modules...
doesn't work:
Bmw edc17c50-recognized as edc17c41
Mercedes edc17c66
Mercedes sid307
Mercedes md1cp001
Renault md1cs006
Renault edc17c84
Works:
Bmw Edc17cp09 dtc off
BMW EDC17C06 WORKS
Bmw Mevd 17.2..
Bmw Mg1
Bmw dtc off in msd80 or msd81d
Hyundai edc17c57
___________________________________________
B.Regards
[attachment=223567]
Thanks given by: maysterecu
rockero69 Offline
(05-25-2025, 04:55 PM)lfas Wrote: DaVinci Deluxe Offline Edition (04.2025)
PRICE:
90$ 1 License.
140$ 2 Licenses
MAF (Mass Air Flow)
LAMBDA (O2 Sensor)
START & STOP
Hello, need information interest one license.
Regards.
lfas Online
Actia
(05-27-2025, 10:48 AM)rockero69 Wrote: Hello, need information interest one license.
Regards.
doesn't work:
Mercedes edc17c66
Mercedes sid307
Mercedes md1cp001
Renault md1cs006
Renault edc17c84
Works:
BMW EDC17C06 WORKS
Bmw Mevd 17.2..
Bmw Mg1
Hyundai edc17c57
B.Regards
