Latest news: ---- Bosch ECU Database v0.3 Tool ---- ZenZefi After Sales Standard Valid Until 2027.02.17 ---- EDC17 IMMO SERVICE TOOL ---- Davinci Deluxe 1.0.XX.0 Full ---- MULTI EDITOR BY DR SALEH FULL ---- Zenzefi Aftersales Certificate 17.02.2027 + 26.11.2026 ---- Lsuite Checksum Tool Full ---- Kubota Service Manuals (FSM) Collection ---- DTS Monaco 8.16.015 Install + Patch + Keygen FULL ---- Multi Editor Honda 1.39.1.0.0 Full ---- Clone OpenPort 2.0 Windows 11 Driver ---- FTAG Checksums Test Fix TOOL ---- DTS Monaco 9.02 Install + Patch + Keygen FULL ---- PCMflash Dongle Manager 0.1.2 China Dongle Emulator ---- Zenzefi Aftersales Certificate 17.02.2027 ---- IMMO SERVICE TOOL 1.2 + INSTRUCTION FULL ---- Renault Can Clip 222 RTL2002 + Patch Full ---- Xentry Cars Passthru OpenShell 09.2026 Xus Das Wis Epc Starfinder Vediamo Monaco ---- VAG IMMO OFF TOOL NEW UPDATE ---- PCMflash Dongle Manager New Update ---- BMW Voltage Monitor TOOL ---- Global TechStream GTS+ Software ---- Seed Key 3.0 Calculator DTS Monaco Vediamo Tool ---- BMW ISTA-PLUS 4.62.11 Programming FULL ---- Alfa Romeo Stelvio Workshop Repair Manual ---- Hex Editor Tool Full ---- BMW ISTA 4.62.1x I-LEVEL OVERVIEW FULL ---- IVECO Power Trucks Buses EPC 2024 Full MEGA ---- IDA PRO 9.4 + KEYGEN FULL ---- PCM Flash Dongle Manager TOOL ----
DST VAG IMMO Tool v4.0 + DST MQB IMMO Sync Calculator
lfas Online
VW
[Image: HOME-DST-VAG.png]
DST VAG IMMO Tool v4- Full activation All modules.
Cost 70$, Offline Version of 02/23/2025, for ECU1, ECU2, TCU, ELV.
Features:
Edit essential data as CS, VIN, MAC, Power Class, number of keys, key data.
Virginisation CP of BCM2
Disable the ELV + ELV Error Fix for Unencrypted BCM2 (Audi A4-A8, VW Touareg)
EZS decryption and editing of IMMO data.
Crafter EZS : clonage + correction kilométrage.
Sync Key Calculator AKL: Module Calculate 32 bytes Sync Key file For Audi A6 A7 A8 and VW Touareg.
CCM (Passat B6/B7/CC) : clonage + extraction IMMO.
ECU MEDC17 (WFS4) : clonage + IMMO OFF (Flash/EEPROM).
TCU MQB : clonage, IMMO OFF, correction du kilométrage.
Simos PCR 2.1 Immo Off
Simos 10.x : extraction + clonage IMMO.
✓ BCM2 A4/A5/Q5 95320 Eeprom
✓ BCM2 A4/A5/Q5 D-Flash
✓ BCM2 A6/A7/A8 VW Touareg
✓ Audi ELV Immo
✓ EZS Immo 1L59W/3L40K 2Kb
✓ EZS Immo 0L01Y 4kb
✓ Crafter EZS
✓ Sync Key Calculator AKL
✓ Simos PCR 2.1 Immo Off
✓ CCM Module
✓ MEDC17 WFS4
✓ TCU DQ200 DQ250 DQ400 MQB
✓ Simos 10.x
___________________________________________________________________
MQB Sync Calculator v1.0: Cost 50$
all-in-one solution for All Keys Lost scenarios on VAG MQB platform vehicles!
his tool calculates Sync Keys and decrypts IMMO data from VAG MQB dashboards in AKL or Immo Module Adapting situation.
Big Thanks to Marcelo Korenfeld for the inputs that helped me to build this tool
How To:
1.To decrypt Immo data, just provide...
The Immo block file from the dashboard.
The sync key from a working key.
2.To calculate a new sync key, provide...
The Immo block file from the dashboard,
OR Dashboard CS + CS from all involved Immo modules,
ECU, TCU, and ELV if equipped.
[Image: MQB-Sync-Calculator-v1-read.png]
