Latest news: ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ---- Volvo Tech Tool PTT 1.12 + Keygen Full ---- xDecoder 14.0 Launcher Package Fix ---- HP Tuners 5.1.1.198 + VCM Keygen FULL ---- SM3 Scanmatik Alpha4 PCMflash ---- JLR SDD ENGINEERING CALCULATOR TOOL ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ----
Radio Code Database Last Update
VAG Calculator (Volkswagen, Audi, Skoda, Seat): This is based on a database of serial numbers. Currently, there  are 660,000 serials loaded.
Philips Calculator: Based on a database of over 14 million codes for various car radio units made by Philips. I've added checkboxes so you can search for your radio code according to the serial number prefix.
Grunding Calculator: This is based on a database of over 7 million codes, containing radio codes for many Grunding radio units installed in various car brands.
Renault/Dacia Calculator: This database allows you to calculate the radio code according to the last 4 digits of the serial number, called the precode (e.g., A100).
Ford Calculator: Currently supports only V and M series with a full database for these series.
Toyota ERC: Based on an algorithm, with improvements to be added in the near future.
Becker Calculator: Based on an algorithm and a database, it supports 4 types of units: 4-digit units, 4-button units, 6-button units, and 8-button units.
GM Database: According to the VIN number, you can get the radio code, key code, IMMO code, and alarm code. It is not a full database yet, currently containing 509,000 VIN numbers.
Chrysler Mode: Based on an algorithm and a database, it supports 4 types of units that can be decoded at this moment.
Fiat: Currently, it can only calculate codes for DIIACI units.
PSA, Fiat, VP1, VP2, Delco CDR2005, and CDR500 for serials starting with GM02051, GM0205X, GM0205Y, GM15001, GM1500X, GM1500Y.
Additional Codes: 1200 new VAG codes have been added.
Bug Fixes: Some minor bugs have been resolved.now all calculators open in same window
TomServis Offline
(05-07-2025, 07:54 PM)Prodrive Wrote: Poslední aktualizace databáze rádiových kódů
password ?
38
I already found it, sorry for the comment
