Latest news: ---- Nissan NERS 4.01 With Calibration Files Mega ---- BMW ISPI ISTA LAUNCHER 1.60.06.2036 FILES MEGA ---- GDS2 Install Complete + Keygen FULL ---- Benz Seed Calc Seed Key Calculator Tool ---- WinOLS 5.80.64Bit File Full ---- VAG ODIS-S 260001.101.180 FILES MEGA ---- VAG ODIS-E 220000.401.10 FILES MEGA ---- Nissan Consult III + Programming Data 226 Files Mega ---- XENTRY OFFLINE LOGIN FIX 12.2025 FULL ---- Renault Dacia DCM Program Full ---- DIAGBOX 9.85 + ACTIVATION FULL ---- PSA MD1CS003 EDC17C60 TPROT REMOVER ---- Peugeot Key Calculator + Keygen ---- Cummins InPower 16 Files Mega ---- Flex Fuel Energy Development Tool Full ---- Citroen C2 Repair Manual ---- Ford IDS 133.01 + Patch Full ---- SCANIA MULTI 25.50.0.0 [2025.09] FILES FULL ---- Toyota Lexus Global Electronic Parts Catalog 2025 Full ---- Bosch ESI [tronic] 2013 Full + Keygen VM Full ---- WINOLS 47 NATIVE INSTALLER FULL ---- BMW E-Sys Setup 3.33.0-53640 Files ---- RANGE ROVER VELAR WORKSHOP REPAIR MANUAL ---- DAF DAVIE 5.6.1 95.00 XDC II FILES MEGA ---- How To Flash NBTevo With E-Sys Tutorial ---- Microsoft Activation Windows Office 07.2026 ---- Honda HDS 3.105.036 + i-HDS 1.009.001 Files 2025 ---- Delphi Autocom Firmware 1622 Modified ---- Toyota ISTA J29 v4.58.41 Full ---- Hello everyone! ----
Jaguar Land Rover JLR SDD 166 2025 - Torrent File
Carsoftcar Online
Land Rover
Jaguar Land Rover JLR SDD 166  - Torrent File
Questions about the password, write in a personal.
Asking for a password in a topic will be ignore.
[Image: fba0b2c28849abed5fa4fe936e0be97b.png]
Year / Release date: 02.2025
Version: 166
System requirements: windows 7 - 11 x86 x64
Interface language: Multilingual
Description:  SDD supports 2007-2016 JLR models.
Additional information: If you want me to do the installation, setup and activation personally, Write me a private message.
Activation instruction with a complex activator:
1) Install vcredist2005_x86
2) Install SDD_166.00.exe
3) For Windows x64, run cmd (Command Prompt as administrator) and type: mklink /D "C:\Program Files\ JLR" "C:\Program Files (x86)\JLR"
4) Without closing the command line, point to the patch.bat file and run it
5) Edit C:\Program Files\JLR\SDD\SDD\app.properties and C:\Program Files\JLR\IDS\SDD\ app.properties and add the following lines to the end of the file:
      sdd.authentication.topix.address = http: //asdaswq.re
      sdd.windows10.enabled = true
      sdd.ie11.enabled = true
6) Run jlr sdd from the desktop
7) Restart Edge in Internet Explorer mode
8) The window shows that the topic is not available. Click "Continue"
9) paste any username and continue
    Need it? Push buttons Rate (Reputation) and Thanks, PM (write in Private Messages) for pass.
voldemaras Offline
Version: 166
  [Image: _9c86ef4dd5b3fd8bcf6af7af13aca1cb.png?md...1739545200]
Rep (Reputation) + Thanks
send password
arbenit Offline
Version: 166
  [Image: _9c86ef4dd5b3fd8bcf6af7af13aca1cb.png?md...1739718000]
Carsoftcar Online
Land Rover
