Latest news: ---- BMW Easy Connect 2 v1.6 TOOL ---- Cmp Hex Tool Full ---- DTS Monaco 9.02 + Keygen + Patch FULL ---- Mercedes Gear Tool Full ---- Scania Xcom 2.54 + Plugin Full ---- GPEC2 GPEC2A FIRMWARES + KEYGEN ---- BMW ISTA-P 3.75.0.400 Modified ICOM A1 A2 Support ---- Complete Automotive Workshop Software Collection Full Version ---- Automatic Transmission Repair Manuals Rebuild Parts ---- BMW ISPI ISTA Launcher Offline Version MEGA ---- Bosch ESI [tronic] 2014 DVD1+DVD2+DVD3 Diagnostic Software ---- L-Suite Checksum Tool 1.03 Full Pack With KSuite DLLs ---- Actia Multidiag J2534 PassThru Support Full ---- hello from norway ---- Cummins Insite 9.3.0.22 Files Mega ---- SWFinder 6.1.8 File MEGA ---- ISTA iLean Voltage 4.61.40 No License No ISPI Admin Client ---- BMW ETK Price 10.2026 ---- Multi Editor Honda Tool Full ---- ECU Circuit Diagram Bosch Schematic ---- BMW FSC GENERATOR MG1 MD1 MSD DME TOOL ---- Wabco Calculator PIN1-PIN2 Activator Keygen ---- BMW Immo Off BTT EWS Deleter v1.1 Immobilizer TOOL ---- Alex Flasher + Keygen Full Version ---- Nexiq Etech 2.13 Setup File Needed ---- BMW ISTA Ilean 4.61.40 VOLTAGE PATCH TOOL ---- ATRIS Stahlgruber + Technik 2018 VM FULL ---- BMW ISTA VOLTAGE PATCH TOOL ---- Davinci 1.0.28 Unlocked Not Require Activation ---- Cnh Est 9.13 ----
Jaguar Land Rover JLR SDD 166 2025 - Torrent File
Carsoftcar Offline
Land Rover
Jaguar Land Rover JLR SDD 166  - Torrent File
Questions about the password, write in a personal.
Asking for a password in a topic will be ignore.
[Image: fba0b2c28849abed5fa4fe936e0be97b.png]
Year / Release date: 02.2025
Version: 166
System requirements: windows 7 - 11 x86 x64
Interface language: Multilingual
Description:  SDD supports 2007-2016 JLR models.
Additional information: If you want me to do the installation, setup and activation personally, Write me a private message.
Activation instruction with a complex activator:
1) Install vcredist2005_x86
2) Install SDD_166.00.exe
3) For Windows x64, run cmd (Command Prompt as administrator) and type: mklink /D "C:\Program Files\ JLR" "C:\Program Files (x86)\JLR"
4) Without closing the command line, point to the patch.bat file and run it
5) Edit C:\Program Files\JLR\SDD\SDD\app.properties and C:\Program Files\JLR\IDS\SDD\ app.properties and add the following lines to the end of the file:
      sdd.authentication.topix.address = http: //asdaswq.re
      sdd.windows10.enabled = true
      sdd.ie11.enabled = true
6) Run jlr sdd from the desktop
7) Restart Edge in Internet Explorer mode
8) The window shows that the topic is not available. Click "Continue"
9) paste any username and continue
    Need it? Push buttons Rate (Reputation) and Thanks, PM (write in Private Messages) for pass.
voldemaras Offline
Version: 166
  [Image: _9c86ef4dd5b3fd8bcf6af7af13aca1cb.png?md...1739545200]
Rep (Reputation) + Thanks
send password
arbenit Offline
Version: 166
  [Image: _9c86ef4dd5b3fd8bcf6af7af13aca1cb.png?md...1739718000]
Carsoftcar Offline
Land Rover
