Latest news: ---- PCMflash Dongle Manager 0.1.2 China Dongle Emulator ---- Zenzefi Aftersales Certificate 17.02.2027 ---- IMMO SERVICE TOOL 1.2 + INSTRUCTION FULL ---- Renault Can Clip 222 RTL2002 + Patch Full ---- Xentry Cars Passthru OpenShell 09.2026 Xus Das Wis Epc Starfinder Vediamo Monaco ---- VAG IMMO OFF TOOL NEW UPDATE ---- PCMflash Dongle Manager New Update ---- BMW Voltage Monitor TOOL ---- Global TechStream GTS+ Software ---- Seed Key 3.0 Calculator DTS Monaco Vediamo Tool ---- BMW ISTA-PLUS 4.62.11 Programming FULL ---- Alfa Romeo Stelvio Workshop Repair Manual ---- Hex Editor Tool Full ---- BMW ISTA 4.62.1x I-LEVEL OVERVIEW FULL ---- IVECO Power Trucks Buses EPC 2024 Full MEGA ---- IDA PRO 9.4 + KEYGEN FULL ---- PCM Flash Dongle Manager TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Link MEGA ---- I have an original Delphi diagnostic ---- John Deere Advistore 5.4.44 ag+cf 2025/07 ---- SIM3K543-E2 ECU Catalyst Off Calibration TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Engineering PET2 PCM FULL ---- XENTRY XUS DAS WIS EPC STARFINDER VEDIAMO MONACO 09.2026 ---- WinOLS File Unlocker Stage Extractor Tool ---- PROGRAM ECU TUNING SOLUTION 1.02 FREE FOR ALL ---- MAGIC TUNERS PACK + KEYGEN FULL ---- PROGRAM ECU TUNING SOLUTION 1.01 FREE FOR ALL ---- PETKA 8.9 FILES + VIN SEARCH FULL ---- MTX DTC REMOVER 1.8.5.0 + KEYGEN FULL ---- AlfaOBD PC Version PRO + Lic Generator ----
hello I need help
raulinonog Offline
Hello, can anyone help me, I'm trying to install scania multi 23.05 and I'm getting this error on disk 2 auth.
Thanks given by: Mbstar , saexy
Khalid0520 Offline
(05-09-2024, 07:06 PM)raulinonog Wrote: Hello, can anyone help me, I'm trying to install scania multi 23.05 and I'm getting this error on disk 2 auth.
0. You may have to remove the previous version of Multi (along with the database).
1. Install Net 3.5
Start - Settings - Applications - Related settings (Programs and Features) - Enable or disable Windows components -> Net Framework 3.5.
Without this, the database will not install.
2. Mount or unzip ISO files. Install in order of priority (01, 02, 03, 04).
3. Run multi_2305_patch.bat with Administrator rights to reset the trial.
!!! If you see the error "Cannot open database Multi_DVD_**** requested by the login. The Login failed.." !!!
You need to change the path to the SQL server.
Launch Multi config from the Start menu.
View the path to the base.
It looks something like this: Multi_DVD_2305_1@MYCOMP\MULTI_SQL.
Edit the patch file - replace the path to the database with yours:
echo sp_password NULL, 1234, sa | OSQL.EXE -S localhost\MULTI_SQL -E
echo use Multi_DVD_2305_1; update multi_proparameter set text="*').$,#(" where item='PROD_STAMP' | SQLCMD.EXE -U sa -P 1234 -S localhost\MULTI_SQL -d Multi_DVD_2305_1
English:
0. Probably: uninstall previous Multi (including db).
1. Install Net 3.5 (need for DB installation)
2. Mount ISO files, then install in order 01, 02, 03, 04.
3. Run as Administrator multi_2305_patch.bat to reset the trial.
!!! If you got a message "Cannot open database Multi_DVD_**** requested by the login. The Login failed.." !!!
You need to replace path to SQL server.
Run Multi config from Windows Start menu.
Check "Folders for Multi data" - "Sql server".
It looks like Multi_DVD_2305_1@MYCOMP\MULTI_SQL.
Open the patch file to edit and replace existing names/pathes to yours:
Thanks given by: Galin90 , SFTY , max9183 , md89nl
kaspare Offline
Hi, you'd better start from scratch with the installation but first you have to clean up all the files of the old multi, uninstall the program from the control panel and then you have to delete this too (MultiCdView) in the programData folder and also delete the various MICROSOFTSQL files from the control panel SERVER of old installations
Thanks given by: forford , mamurozbot , AMSTER , Spawnrn
