Latest news: ---- XPROG 5.5.5 NO DONGLE NEED FULL ---- SCANIA SDP3 V2.70.1.3 FULL TRUCKS + MARINE + KEYGEN ---- BMW ISTA Updater GUI 2.0.0 TOOL ---- Bendix VCP ---- BMW Easy Connect ECC ISTA TOOL ---- VCM EDITOR COLLECTION FULL ---- VCDS Release 26.3.0 VIIPlus Loader 08.026.08 FULL ---- Winols 4.7 With Installer Full Mega ---- BMW CAS4+ EDITOR TOOL FULL ---- BMW ISTA 4.61.1x VERSION AND I-LEVEL OVERVIEW ---- ProSeCco Data Time Tool Full ---- CDA 6-J2534 bridge (Dubb45 Tool to use CDA with Passthru) ---- Subaru SSM4 Universal J2534 + Patch Full ---- Xentry Full Fix 4.9.8 Soft Easiest Installation Activation ---- Diagbox 7.57 Pack Complete Full ---- ODIS-S 26.0.1 + ODIS-E 22.0.0 + Fix Last Update ---- GM ECU FLASHER TOOL FULL ---- Hino DX3 v1.25.1 Diagnostic Solution Files Mega ---- Winols EDC15 Mappack Generator TOOL ---- xDecoder + Keygen 100% Work ---- VAG PCR 2.1 DECODER TOOL FULL ---- SDD use for LR Discovery 4 ---- Toyota Lexus GTS+ 2026 Offline Diagnostic Software ---- ECU Tuning Solutions + Keygen IMMO DTC EGR DPF ADblue OFF ---- BMW PSdZData 4.61.11 Torrent File FULL ---- BMW ISTA+ 4.60.30 Standalone Files FULL ---- GM GLOBAL B SEED KEY CALCULATOR ---- BMW ISTA Standalone 4.61.12 FULL MEGA ---- CAT SIS 01.2018 TORRENT FILE FULL ---- BMW ISTA GUI 1.4.6 TOOL FULL ----
Bmw ecu change
V!LL! Offline
Hi!
 Im trying to help my father to fix he´s car. Bmw e46 touring  2.0 diesel.
As in the car history it have had water damage he thinks that the problem is the ecu. There is lots of smoke coming and is running rough.
There have changed injectors and coded with INPA. changed alsou rail pressure controller and sensor (pressure is ok). last error codes was for all glow plugs. So I send him the glow plugs and the controller box. But he changed only the box as he say glow plugs are fine.  Dodgy and he pushed me to buy also another ecu wich I did. thinking its easy to synchronize to immo and keys but with INPA cannot. I found the thing about Virginizeing or OFF. So first I got the flash read with KESS. Then I came across this forum trying to find a program but this needs activation and the other tool I could not intsall It say theres a problem with my computer. So maybe somebody here have the programm set up and can help me to get this immo off.
Bullitt Offline
(03-07-2024, 08:12 PM)V!LL! Wrote: Hi!
PM you
