Latest news: ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ---- Volvo Tech Tool PTT 1.12 + Keygen Full ---- xDecoder 14.0 Launcher Package Fix ---- HP Tuners 5.1.1.198 + VCM Keygen FULL ---- SM3 Scanmatik Alpha4 PCMflash ---- JLR SDD ENGINEERING CALCULATOR TOOL ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ----
PERKINS-ENGINES-SERVICE REPAIR MANUAL-USER HANDBOOK-SCHEMATIC-ALL SERIES
pitercar Offline
PERKINS-ENGINES-SERVICE REPAIR MANUAL-USER HANDBOOK-SCHEMATIC-ALL SERIES-110 $
PDF-FILES
LANGUAGE-English
Payment-PAYPAL-SKRILL-CRYPTO-PAYSAFE-WESTERN UNION-REVOULT-N26
Shipping options: Link to download from fast server
Shipment to PENDRIVE MEMORY to the registered post address provided.
More information PM:
ONE SERIES-50$
ALL SERIES-TOTAL-110$
  WORKSHOP MANUAL=SERVICE REPAIR MANUAL
Content All:
ELECTRICAL CONNECTORS
OPERATION AND MAINTENANCE MANUAL
PART BULLETINS
PARTS COMPARISON BULLETINS
PARTS KIT INSTRUCTIONS
PERKINS ENGINE NUMBER GUIDE
SERVICE BULLETINS
SERVICE DATA BOOKLET-PART1-MATURE PRODUCTS UP TO 8,85 LITRES
SERVICE DATA BOOKLET-PARR-CURRENT PRODUCTS UP TO 8,7 LITRES
SERVICE LETTERS
SERVICE MANUALS
SERVICE TOOLING
SPECIAL INSTRUCTIONS
SERVICE MANUAL-Contents:
SERIES 3.152
SERIES4 CYLINDER
SERIES 6 CYLINDER
SERIES 100
SERIES 200-300 SERIES400
SERIES 500-PRIMA
SERIES 700
SERIES 800-800 C
SERIES 800-800 D
SERIES 850
SERIES 900
SERIES 1000
SERIES 1100
SERIES 1200
SERIES 1300
SERIES 1500
SERIES 1600
SERIES 2000-EAGLE
SERIES 2200-2500-2800
SERIES 2300
SERIES 3000
SERIES 4000
SERIES V8.540-V8.510
SERIES VS.640
ELECTRICAL CONNECTOR-Contents:
NEW STARTER WIRING
OPERATION AND MAINTENANCE MANUAL-Contents:
MODEL-4012 TESl-4016 TESI
MODEL-4016 TAGl-4016 TAG2
MODEL-AA  to AH
MODEL-BK
MODEL-BL MODEL-BM-BN
MODEL-BQ-BP
MODEL-DE6-DE8
MODEL-E08-E06
MODEL-EG-EH-EJ-EK
MODEL-EL-EN-EP
MODEL-ER-EQ-EW
MODEL-FJ
MODEL-FT-FE
MODEL-FX-FW-FM-FL
MODEL-G16
MODEL-GAS
MODEL-GG-GH-GJ-GK-GL-GM-GN-GP-GR-GS-GT-GU-GV
MODEL-HB-HD-HH-HL-HM-HN-HP-HR
MODEL-IH-IF-IG-IZ-IS-IK-IJ-IN
MODEL-IN84182-IN84331-IN84360-IN84372
MODEL-IR-IQ-IW
MODEL-JGK-P84-PP8
MODEL-JG-PK8
MODEL-JR-JS-JT-JV
MODEL-JU
MODEL-KHG
MODEL-LG-PK9
MODEL-LN-LQ-LR MODEL-LT-LU-LV
MODEL-MGA-MGB-MGD MODEL-MK-ML
MODEL-MT-MU-MW
MODEL-NGK-VGF-VGE
MODEL-NGW-YG
MODEL-NH-NJ
MODEL-NK-NL-NM
MODEL-NP-NR
MODEL-PJ
MODEL-PK
MODEL-PK3
MODEL-PK5
MODEL-PP3-PP4-TGK
MODEL-PP5
MODEL-PP8
MODEL-PP-PR-PT-PU
MODEL-PV-PW
MODEL-R5H
MODEL-R8H
MODEL-RE-RG-RJ-RR-RS-RT-DC-DD-DF-DG-DJ-DK
MODEL-S12
MODEL-S16
MODEL-SD8-SD6-DGBH
MODEL-SU-ST
MODEL-TGB-TGD-TGF
MODEL-UK-UL
MODEL-WG6
MODEL-WK-WL-WM-WN-WP-WQ-WR-WS
MODEL-XGA-XGB-XGD-XGE-XGF-XGH
MODEL-XK-XL-XM
MODEL-YA to YD
PARTS BULLETINS-Contents:
3.152 - 1000 Series4 Cylinder Assemled Long Engines
3.152 Agricultural Engine Overhaul Kits
3.152 Industrial Engine Overhaul Kits
400 Series Long Engines
400C Power Exchange Long Engines
700 & 900 Series Valvetrain Kits
1000 Series Exchange Crankshafts
1000 Series Exchange Cylinder Heads
1103C & 1104C Cylinderre-bore
1104 -1106 NEW FOR OLD TURBOCHARGERS NOW AVAILABLE
1104D Electronic Secondary Fuel Filter Change
1106D Series Service Tools List
2300 - 2500 - 2800 Series Valve Seat Inserts
2300 & 2800 SERIES TOOLSLIST-GBP
2300, 2500 and 2800 Series Service Tools List
2656F843-Packaging Change
4000 Series Exchange Gas Cylinder Heads
Bearing Rationalisation and Material Change V2
Brand Protection
Change of Moulded Anti-Drain Diaphragm on Key Oil Filters
Change to Unit of Issue
Compact Communication Adapter
CRANK WEAR SLEEVE AVAILABILllY
Extended Service Contract Pricing Review
Filter Cross Reference Update
Fractured Split Connecting Rods
Introducing Power Exchange Part Numbers Look For The R
Launch of the Parts Help Desk Web Front-end
Logic Control Governor 1 (LCG1) conversion to Logic Control Governor 2 (LCG2)
Long Engine Kits
Minor and Major Cylinder Head Kits
New and improved front oil seal!
NEW FILTER SALES SUPPORT TOOLS
OIL COOLER GASKET KITS
Packaging Material Change
PDF Parts Books
Perkins Genuine Filters -Changes to 26561118
Perkins Genuine Filters- Changesto Design
Perkins Overhaul Kit Breakdown Matrix
Piston Ring Kit Packaging Change
POWERPART EXTENDED  LIFE COOLANT
Recommended parts list for new 4006 engines
Roll out of Peterborough Pre-1978 Engine Data
Soft Gasket Material Change
The Integrated Product Support Solution (TIPSS) Software Help And Support Contacts
Tier 0 1000 Series Exchange Short Engines
Tier 1 'New' 1000 Series Exchange - Assembled Long Engines
Tier 1 'New' 1000 Series Exchange Short Engines
TIPSSand ONLINE LICENSING
Water Pump Repair Kit Phase Out
PARTS COMPARISON BULLETINS-Contents:
PERKINS REAR END OIL SEAL-REOS-VS CONTERFEIT
PERKINS CRANKSHAFT AGAINST THE IQ CRANKSHAFT
PARTS KIT INSTRUCTION-Contents:
4.41 Cylinder Block Or Cylinder Head Kit
100 and 400 Series cylinder head gaskets
700 Series engine overhaul kit
700 Series engine valve train kit
700,900 and 1000 series long engine kit
800 Series Core Plug Replacement
800 Series Electrical Connection Kit
900 Series Cylinder Head Kits
900 series engine overhaul parts kit
900 Series engine valve train kit
1000 Series Overhaul Kit
1100 Series Atomisers
1100 Series Fuel Injection Pump
1100 Series Naturally Aspirated 4 cylinder Part Leak Off Pipes Kit
1100 Series oil and intake manifold pressure connectors
1100 Series oil and intake manifold pressure connectors-2 1
1060 Cap Kit
2000 Series Power Exchange long Engines
3000 series engine cooling fan parts kit
Additional Fuel Fier Kit
Assembled Long Engines 3.152 and 1000 Series 4 Cylinder
Bearing Kits
Camshaft Position Sensor Kit
Check for damage to the rubber blanking cap
Check The rubber blanking cap
Conversion for Long Engines
Conversion of the ignition system
Crankshaft Front Seal
Crankshaft palm tapped holes for 6.354,6.60and 6.601engines
Crankshaft liming Ring
Cylinder Block Kit For A Short Engine
Cylinder Block Kit
Cylinder Head Bolts Cylinder Head Valve Seat Kit
Cylinder Sleeve and Sealing Ring Kit
DPG-2104 Controller
Electrical Connections for the Analog Throttle Pedal
Electrical Connections for the PWM Throttle Pedal
Electronic Control Governor
Electronic Unit Injectors - Remove and Install
Electronically Governed Stanadyne Fuel Injection Pumps
Eliminating Leakage from the Oil Filter Head Sealing Face on 800 Series engines
Engine Oil Cooler
Engine Oil Pump Idle Gear
Engine Serial Numbers for Short Engines
Fitting bearing shells intofractured split connecting rods
Fitting of a 'long engine'
Fractured -split connecting rods for turbocharged 6354.4,4.236, 1000 Series4 and 6 cylinder and 1100 Series 6 Cylinder engines
Fuel Injection Pump Locking Screw and Locking Spacer
Fuel injection pump rated speed
High Pressure Fuel Linesfor engine model PJ
Injector leak-off rate measurement procedure
Installation of BFPM Conversion Kit (Four Cylinder Engines)
Installation of Cold Climate Kit for 4 Cylinder Engines
Installation of Cold Climate Kit for 6 Cylinder Engines
Installation of Coolant Expansion Tank
Installation of Differential Pressure Sensor (NRS) Kit
Installation of New Engine Oil Pump
Installation of New Fuel Priming Pump (BFPM)
Instructions for Fitting and Servicing 11060 Turbos
Instructions to fit a bridge piece
Instructions to fit a new turbocharger
Instructions to fit a new turbocharger-2
JPT ESOS Introduction and conversion
Machining of new cylinder liners fitted to 900 Series engines
Mounting Bracket Part 2634A157
Mounting Kits for Fuel Priming Pump
New 1000 series engine overhaul parts kit
New 1000 Series exhaust manifolds
New Primary Fuel Filter Element
New rear end oil seal
New Secondary Fuel Filter
New timing case covers and 'O' ring
Oversized pistons for 1103 and 1104 Series Engines
Perkins 900 Series Cylinder block kit (ZZ50304)
Perkins Consumables
Perkins LC Governor Installation
Perkins Water Pumps
Phaser-1000 Series Cylinder Block Kit
Power Exchange Crankshaft Kits
Power Exchange Long Engines-2
Power Exchange Long Engines-3
Prima Head Gasket Incorrectly Stamped
Prima Short Engines
Protection Kit (3724232)
Protection Kit (3724232)-2
Protection Kit (3881289)
Protection Kit (3932259)
Protection Kit
Replacement of Vibration Isolatorsfor the Fuel Filter-Lift Pump Assembly
Replacement Water Pump
Replacing Logic Control Governor 1 with the new Logic Control Governor 2
Sealing of the lubricating oil cooler and blanking plate
Service timing kit U5MK0396
Starter Motor Introduction
To fit the new three-piece exhaust manifold to New 1000 Series engines
Tofit the timing ring tothe crankshaft for 1104 and 1106 engines
To setthe flight speed
Valve stem oil seals for the 1100 Series 3 and 4 Cylinder engines
Valve Train Kits
Wastegate Actuator  Replacement
Wiring Diagram for Coolant Level Switch Kit (Perkins kit number CV25001)
PERKINS ENGINE NUMBERS GUIDE-Contents:
SERVICE BULLETINS-Contents:
3.152 SERIES-C
4.107-4.108 SERIES-EA
4.165 SERIES-GA
4.203 SERIES-JD
4.236 SERIES-LM
6.354 SERIES-TC
6.3544 SERIES-TW
100 SERIES-K
130 SERIES-W
200-300 SERIES-G
400 SERIES-H
500 SERIES-B
700 SERIES-U
800 SERIES-UE
854 SERIES
900 SERIES-CP
1000 SERIES-A
1100 SERIES-R
1200 SERIES
1300 SERIES-W
1600 SERIES-XG
2000 SERIES-S2
2200 SERIES-TG
2500 SERIES-MG
2800 SERIES-FH
3000 SERIES-S3
4000 SERIES-D
EAGLE SERIES-SE
GENERALSERVICE BULLETINS
T6.3543 SERIES-TP
V8 540-640 SERIES-X
SERVICE DATA BOOKLET -PART1-MATURE PRODUCTS UP TO 8,85 LITERS-Contents:
PART1
SERVICE DATA BOOKLET-PART2-CURRENT PRODUCTS UP TO 8,7 LITERS-Contents:
PART2
SERVICE LETTERS-Contents:
400 SERIES-New Flash Files
400 SERIES-Nuts for Rocker Shaft
400 SERIES-Piston Kits
400 SERIES-Replacement of the Engine
1100 SERIES-Charge Cooler Tube Assembly
1100 SERIES-Crankshaft Timing Ring -2
1100 SERIES-Crankshaft Timing Ring-3
1100 SERIES-Crankshaft Timing Ring-4
1100 SERIES-Cylinder Head Valve Adjustment Screw
1100 SERIES-Emissions Certification Film - Replace
1100 SERIES-Engine Oil Pump
1100 SERIES-Replacement Electronic Control Module
1100 SERIES-Tube Assembly
1200 SERIES-Engine Oil Pressure
1200 SERIES-Flash File Update
1200 SERIES-New Flash File
1200 SERIES-New Flash Files
1300 SERIES-Engine Wiring Harness
2200 SERIES-Fan Drive Bolts
4000 SERIES-Bolts for the Fuel Linkage
4000 SERIES-Charge Cooler
SERVICE MANUALS-Contents:
SERIES 3.152
SERIES4 CYLINDER
SERIES 6 CYLINDER
SERIES 100
SERIES 500-PRIMA
SERIES 700
SERIES 800-800 C
SERIES 800-800 D
SERIES 850
SERIES 900
SERIES 1000
SERIES 1100
SERIES 1200
SERIES 1300
SERIES 1500
SERIES 1600
SERIES 2000-EAGLE
SERIES 2300
SERIES 3000
SERIES 4000
SERIES VS.640
3.152 SERIES-USER HANDBOOK
3.152 SERIES-WORKSHOP MANUAL
SERIES 4.41
SERIES 4.108
SERIES 4.154
SERIES 4.165
SERIES 4.192
SERIES 4.203
SERIES 4.2032
SERIES 4.2482-4.248-T4.236-4.236-4.212-T4.38
SERIES G4.203
SERIES G4.236
SERIES 6.247
SERIES 6.254
SERIES 6.354-T6.354-6.3542-6.372
SERIES 6.3544-T6.3544-6.3724
SERIES T6.3543
SERIES 100-USER HANDBOOK
SERIES 100-Workshop Manual
SERIES 200-300-USER HANDBOOK
SERIES 200-300-Workshop Manual
400 A-D SERIES-GG-GH-GJ-GK-GL-GM-GN-GP-GR-GS-GT-GU-GV
400 C SERIES-HB-HD-HH-HL-HN-HP-HR
400 F SERIES-EL-EN-EP
400 F-E SERIES-ER-EQ-EW
404 A-EX SERIES
500-PRIMA-Workshop Manual
500-User Handbook
PRIMA 80T-User Handbook
SERIES 700-UA-UB-UC
Workshop Manual
User Handbook
SERIES 800-800C
DISASSEMBLY AND ASSEMBLY-UE-UF
OPERATION AND MAINTENANCE MANUAL-UE-UF
SPECIFICATIONS-UE-UF
SYSTEMS OPERATION TESTING ANDADJUSTING-UE-UF
SERIES 800-800D
DISASSEMBLY AND ASSEMBLY-UK-UL
OPERATION AND MAINTENANCE MANUAL-UK-UL
SPECIFICATIONS-UK-UL
SYSTEMS OPERATION TESTING AND ADJUSTING -UK-UL
SERIES 850
854F-E34T AND 854E-E34TA
854F-E34TA-ENGINE-56kw-JU
CUSTOMER ASSEMBLY-1204F-E44TAA-MT-MU-854F-E34T-JS-JT-1206F-E70TA-BM-BN
SERIES 900-CP·CR-USER HANDBOOK
SERIES 900-CP·CR-WORKSHOP  MANUAL
SERIES 900-CT GAS USER HANDBOOK
SERIES NEW 1000-AF-GAS-USER HANDBOOK
SERIES NEW 1000-AF-GAS-WORKSHOP MANUAL
SERIES NEW 1000-AJ-AS-YG-YK-USER HANDBOOK
SERIES NEW 1000-AJ-AS-YG-YK-WORKSHOP MANUAL
SERIES 1000-AA-AH-YA-YD-USER HANDBOOK
SERIES PHASER 135Ti-AL-EURO 2-WORKSHOP MANUAL
SERIES PHASER-1000-AA-AH-YA-YE-WORKSHOP MANUAL
SERIES PHASER-AA-AE-YA-YE-USER HANDBOOK
SERIES PHASER-AL-EURO 2-USER HANDBOOK
SERIES 1100
1103 D-XK-XL-XM-INDUSTRIAL ENGINES
1103-1104 ABC-RE-RG-RJ-RR-RS-DC-D  D-DF-DG-DJ-DK-INDUSTRIAL  ENGINES
1104 C-RF-RH-RK-ELECTRONIC-INDUSTRIAL  ENGINES
1104 D-E44T-1104 D-E44TA-NP-NR-INDUSTRIAL ENGINES
1104 D-NH-NJ-INDUSTRIAL ENGINES
1104 D-NK-NL-NM-INDUSTRIAL ENGINES
1106 A-C-D-PP-PR-PT-PU-INDUSTRIAL ENGINES
1106 C- 1106 D-PV-PW-INDUSTRIAL ENGINES
1106 C-PK-GENSET
1106 C-VK-INDUSTRIAL ENGINES
1106 D-PJ-INDUSTRIAL ENGINES
ELECTRONIC DIAGNOSTIC DEVICE-USERS HANDBOOK
PERKINS LOGIC CONTROL GOVERNOR ONE-LCG1-PERKINS LOGIC CONTROL GOVERNOR TWO-LCG2
THE DURABILllY OF THE FUEL SYSTEMS
SERIES 1200
1204 E-E44TA-1204  E-E44TTA-1206  E-E66TA-BK-MK-Ml-ENGINES
1204 E-E44TA-1204  E-E44TTA-MK-Ml-INDUSTRIAL ENGINES
1204 F-E44TA-1204  F-E44TTA-MT-MU-MW-INDUSTRIAL ENGINES
1206 E-70TTA-BL-ENGINES
1206 E-E66TA-BK-INDUSTRIAL ENGINES
1206 F-E?OTA-1206 F-E70TTA-BM-BN-INDUSTRIAL ENGINES
DEF CLEANLINESS KITFOR 1200F
SERIES 1300
PEREGRINE AND NOW GENERATION 1300 SERIES-WD-WJ
PEREGRINE EDi AND 1300 SERIES EDi-WK-WS
PEREGRINE-1300 SERIES-WB-WC
SERIES 1500
1506 A-C-D-LG-PK9-INDUSTRIAL ENGINES
SERIES 1600
1600 SERIES-XGA-XGB-XGD-XGE-XGF-INDUSTRIAL ENGINES
SERIES 2000
ALL 2000 DIESEL MODELS-USERS HANDBOOK
MODELS 2006 SIAND 2006TSl-GAS-USERS HANDBOOK
WORKSHOP MANUAL
SERIES EAGLE
EAGLE 800-EAGLE TX-EAGLE TX 2000-WORKSHOP MANUAL
EAGLE TX 2000-USERS HANDBOOK
EAGLE TX AND EAGLE 800-USERS HANDBOOK
SERIES-2200-2500-2800
2206 D-E13TA-PK3·INDUSTRIAL ENGINE
2206 F-E13TA 2506 F-El5TA-2806 F-E18TA-P84-PP5-PP4-INDUSTRIAL ENGINES
2206 F-E13TA-PP3-PP4-INDUSTRIAL ENGINE
2206-E13-TGB·TGD-TGF-INDUSTRIAL ENGINE
2506 D-El5TA-PK5 1-UP-INDUSTRIAL ENGINE
2506 D-El5TA-PK5-INDUSTRIAL ENGINE
2506 D-El5TA-PK5-UP-INDUSTRIAL ENGINE
2506 F-El5TA-2806 F-El8TA-P84-PP5-INDUSTRIAL ENGINES
2806 C-E16-INDUSTRIAL ENGINE
2806 C-E18TA-2806 D-El8TA-2806 D-E18TTA-JG-PK8-INDUSTRIAL ENGINES
2806 F-E18TA P84-INDUSTRIAL ENGINE
SERIES 2300
2306A-E14-2306 C-E14-DIAGNOSTIC MANUAL
2306A-E14-2306 C-E14-USERS HANDBOOK
2306A-E14-2306 C-E14-WORKSHOP MANUAL
SERIES 3000
3008 GAS SERIES
3008 SERIES
3012 GAS SERIES
3012 SERIES
SERIES 4000
4006 TRS GAS-4008 TRS GAS-SG6-SG8-INDUSTRIAL ENGINES
4006-8-DIESEL ENGINE
4006-23-4008-30-SD8-SD6-INDUSTRIAL ENGINES
4006-4008-GAS ENGINES
4008-30-SD8-INDUSTRIAL ENGINE
4012-16-DIESEL ENGINE
4012-16-GAS ENGINE
4012-46A-S12-IDUSTRIAL ENGINE
4016-61TRG-S16-INDUSTRIAL  ENGINE
4016-E61TRS-GAS ENGINES
4006 TRS GAS-4008 TRS GAS-4012-46A-4016-61A-PANDAROS DIGITAL GOVERNOR
SERIES V8.540-V.8.510
V8.510-V8.540-TV8.540-WORKSHOP  MANUAL
V8.540-USERS HANDBOOK
SERIES V8.640
V8.640-TV8.640-WORKSHOP  MANUAL
V8.640-USERS  HANDBOOK
SERVICE TOOLING-Contents:
ENGINE TOOL LIST
SPECIALIST TOOL CATALOGUE
SPECIAL INSTRUCTION-Contents:
SPECIAL INSTRUCTIONS HAVE BEEN MOVED UNDER SERVICE MANUALS
