Latest news: ---- PETKA 8.9 FILES + VIN SEARCH FULL ---- MTX DTC REMOVER 1.8.5.0 + KEYGEN FULL ---- AlfaOBD PC Version PRO + Lic Generator ---- VCDS 26.9.0 LAST VERSION + LOADER FULL ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ----
MAN Cats II, ELTIS, Mantis 2026, WIS, Developer Tool + Calculator - Remote Install
Carsoftcar Online
Man
MAN Cats II 14.1 2014, ELTIS 2016, Mantis EPC 2026, WIS 2015, Developer Tool + IMMO Calculator - Remote Install
We provide a service for removing the installation and activation of software.
Car, truck, agricultural machinery and construction machinery.
Pay by PayPal or other convenient methods.
Warranty and post-sales service. 7/24 service and discount system.
  • MAN Cats II 14.1 2014 (Acronis image, configured for DPA5, mini VCI Xhorse, Nexiq, Scanmatik, Vocom) - $150
  • MAN WIS (Workshop Infosystem) 01.2015 - $75
  • MAN Developer Tool + IMMO Calculator - $139
  • MAN ELTIS v3 2016 - $100
  • MAN Mantis EPC 7.0.4.3 03.2026 - $160
MAN-cats II 14.1 2014 is an external diagnosis system with the most extensive test depth for electrical systems in MAN commercial vehicles.
Using MAN CATS, you can perform the following functions:
  • identification of systems of electronic control units
  • reading, decoding, and deleting trouble codes
  • special tests of actuators
  • monitoring systems (display and evaluation of current signal data from sensors)
  • guided troubleshooting functions
  • work with service functions and control of a technical condition
  • coding and replacement of electronic control units.
MAN ELTIS
It's a spare parts catalog that contains original spare parts for MAN engines, spare parts for marine engines MAN, marine engines MAN, MAN engines for construction, and agricultural machinery. In the catalog of MAN motors, there is a choice by engine model, as well as a search by engine number.
[Image: MAN-ELTIS-Electronic-Parts-Catalogue-600x600.jpg]
Man Mantis EPC spare parts catalog presents spare parts for trucks, tractors, buses, engines.
In the new version of the program, it allows you to enter the full VIN of the machine for identification, but it only determines the model and release date by VIN. There is a search for a picture by the original part number and a list of vehicles where the part was used, as well as replaced part numbers, both new and old.
MAN WIS dealer documentation for the repair of trucks and buses MAN. This program contains information on repair, maintenance, diagnostics, electrical circuits. This repair manual serves as an aid to the proper repair work on the vehicles and assemblies described here and reflects the technical level.
MAN Developer Tool + IMMO Calculator. It needs for:
  • FFR-EDC pairing
  • FFR parts number changing
  • FFR / EDC VIN number changing
  • IMMO PIN codes for Key Learning
  • Language programming/changing
  • New/Used ECUs programming.
If you need it - write to us and we will discuss details!
Thanks given by: ThonaserNam
Carsoftcar Online
Man
MAN Mantis EPC 11.2023 - $100
Carsoftcar Online
Man
MAN Mantis EPC 02.2024 - $170
Carsoftcar Online
Man
MAN Mantis EPC 12.2024 - $150
DedemOglu Online
(05-09-2023, 12:26 PM)Carsoftcar Wrote:
MAN Cats II 14.1 2014, ELTIS 2016, Mantis EPC 2024, WIS 2015, Developer Tool + IMMO Calculator - Remote Install
  • MAN Cats II 14.1 2014 (Acronis image, configured for DPA5, mini VCI Xhorse, Nexiq, Scanmatik, Vocom) - $85
  • MAN WIS (Workshop Infosystem) 2011 - $40
  • MAN WIS (Workshop Infosystem) 01.2015 - $95
  • MAN ELTIS 2011 - $30
  • MAN ELTIS 2013 - $80
  • MAN ELTIS v3 2016 - $120
  • MAN Mantis EPC 2020 - $50
  • MAN Mantis EPC 11.2023 - $100
  • MAN Mantis EPC 12.2024 - $150
[Image: default_opengraphimage.jpg?ts=2478993894]
MAN ELTIS
  • FFR-EDC pairing
Hello
does it also work with MAN TGX3
thx
(09-23-2025, 11:01 AM)DedemOglu Wrote:
(05-09-2023, 12:26 PM)Autosoftcar Wrote:
MAN Cats II 14.1 2014 , ELTIS 2016,  Mantis EPC 2024 , WIS 2015 , Entwicklertool + IMMO-Rechner –  Remote-Installation
Wir bieten einen Service zum Entfernen der Installation und Aktivierung von Software an.
PKW, LKW, Landmaschinen und Baumaschinen.
Bezahlen Sie per PayPal oder anderen bequemen Methoden.
Garantie und Kundendienst. 7/24-Service und Rabattsystem.
  • MAN Cats II 14.1 2014 (Acronis-Image, konfiguriert für DPA5, Mini-VCI Xhorse, Nexiq, Scanmatik, Vocom) –  85 $
  • MAN WIS (Werkstatt-Infosystem) 2011 –  40 $
  • MAN  WIS (Werkstatt-Infosystem)  01.2015  -  95 $
  • MAN -Entwicklertool + IMMO-Rechner –  139 $
  • MAN ELTIS 2011  –  30 $
  • MAN ELTIS 2013  –  80 $
  • MAN  ELTIS v3  2016  –  120 $
  • MAN Mantis EPC 2020 – 50 $
  • MAN  Mantis EPC  11.2023  -  100 $
  • MAN  Mantis EPC  12.2024  –  150 $
MAN-cats II 14.1 2014  ist ein externes Diagnosesystem mit der umfangreichsten Prüftiefe für elektrische Systeme in MAN-Nutzfahrzeugen.
Mit MAN CATS können Sie folgende Funktionen ausführen:
  • Identifikation von Systemen elektronischer Steuergeräte
  • Lesen, Dekodieren und Löschen von Fehlercodes
  • spezielle Tests von Aktoren
  • Monitoringsysteme (Anzeige und Auswertung aktueller Signaldaten von Sensoren)
  • Geführte Fehlerbehebungsfunktionen
  • Arbeit mit Servicefunktionen und Kontrolle eines technischen Zustands
  • Codierung und Austausch elektronischer Steuergeräte.
MAN ELTIS
ist ein Ersatzteilkatalog, der Originalersatzteile für MAN-Motoren, Ersatzteile für Schiffsmotoren von MAN, Schiffsmotoren von MAN, MAN-Motoren für Bau- und Landmaschinen enthält. Im Katalog der MAN-Motoren gibt es eine Auswahl nach Motormodell sowie eine Suche nach Motornummer .
Der MAN Mantis EPC- Ersatzteilkatalog präsentiert Ersatzteile für LKW, Traktoren, Busse und Motoren.
In der neuen Programmversion können Sie zur Identifizierung die vollständige Fahrgestellnummer der Maschine eingeben, Modell und Erscheinungsdatum werden jedoch nur anhand der Fahrgestellnummer ermittelt. Es gibt eine Bildsuche anhand der Originalteilenummer und eine Liste der Fahrzeuge, in denen das Teil verwendet wurde, sowie die Nummern der ersetzten Teile, sowohl neuer als auch alter. MAN WIS- Händlerdokumentation für die Reparatur von LKW und Bussen von MAN. Dieses Programm enthält Informationen zu Reparatur, Wartung, Diagnose und elektrischen Schaltkreisen. Dieses Reparaturhandbuch dient als Hilfestellung für die sachgemäße Reparatur der hier beschriebenen Fahrzeuge und Baugruppen und spiegelt den technischen Stand wider. MAN Developer Tool + IMMO Calculator. Benötigt für:
  • FFR-EDC-Paarung
  • Änderung der FFR-Teilenummern
  • FFR/EDC-VIN-Nummer ändern
  • IMMO-PIN-Codes für Key Learning
  • Sprachprogrammierung/-änderung
  • Programmierung neuer/gebrauchter Steuergeräte.
Wenn Sie es brauchen –  schreiben Sie uns  und wir besprechen die Details!
Hallo
, funktioniert es auch mit MAN TGX3
, danke
Carsoftcar Online
Man
MAN Mantis EPC 7.0.4.3 01.2024 - $160
Carsoftcar Online
Man
Thanks given by: DennisereHeK
