Latest news: ---- Dump Tool Editor Full ---- HardCut Limiter Pop Bang Package 3+1 ---- Winols 2.24 Full Activated ---- Opel CIM Pin Calc v2 Full ---- CAS3++ 1.2 TOOL FULL ---- Tachosoft 23.1 Key Full ---- BMW Editor CAS3+ Patched FULL ---- Real Sirius 32 Immo Cleaner Tool ---- Davinci Deluxe edition 2025 1.0.37 Token Full ---- Multi Immo Prog v0.2 Full ---- Kobelco Service Repair Manual Collection ---- VAG-SIMOS 3PA 3.3 93C76 IMMO OFF ---- Renault Dacia 42 ECU TOOL ---- Learning WinOLS Videos Collection ---- VCDS ENG FRM 24.7.0 Kolimer FULL ---- IAW4 v1.2 Immo Off Tool FULL ---- Kia Hyundai Vin To Pin Tool ---- Immo Box Locations All Key Lost Maker ---- PCM Helper v1.2 FULL ---- MARELLI IMMO REMOVER TOOL ---- Immo PIN Code Calculator Full ---- ECU File Info Software ---- Easy Kill v2.0 Tool Full ---- BMW ISTA+ 4.59.3x Install Files MEGA ---- Hex Editor Tool On-line ---- Renault Can Clip Registation 2029 Tool ---- PCR 2.1 Decoder Immo Remover Software ---- BMW ESys Setup 25.10.03 File MEGA ---- CHECKSUM CORRECTOR TOOL ---- SUBARU SSM3 SSM4 LOADER FULL ----
TOYOLEX 3 for DPF EGR DTC AdBlue IMMO more.. (Toyota,Lexus,Denso)
lfas Offline
Toyota
TOYOLEX 3 for DPF EGR DTC AdBlue IMMO IMV disable…, costs 90$
[Image: 22120910525225315418066400.png]
ToyoLex 3 software, supports binary files of all 3 generations of Toyota and Lexus Denso Engine Control Units on the market, gasoline, diesel, and hybrid engines.
features:
– New algorithm that recognizes Generation 3 DTC tables structure embedded in Denso Generation 2 files.
– Added a new algorithm that allows DTC erase function on Hybrid engine vehicles.
– Adblue / SCR System disable function.
– DieselParticulate Filter [DPF] disable the function for all Denso Generations ECUs.
– Vehicle speed limiter [Vmax] correction function for 1GD-FTV, 2GD-FTV, 1KD-FTV, and 2KD-FTV Diesel engines.
– Catalyst System [CAT – Lambda sensor] disable the function for 1GD-FTV and 2GD-FTV diesel engines.
– Catalyst System [CAT – Lambda sensor] disable the function for all gasoline engines.
– Exhaust Gas Recirculation [EGR] disable function.
– Intake Manifold Valve [IMV] disable function.
– Intake Manifold Runner [IMR] disable function.
– Immobilizer disable function [IMMO OFF] on 1KD-FTV, 2KD-FTV, 1GD-FTV and 2GD-FTV with Denso GEN 2 ECUs.
ToyoLex 3 supports binary files from the following flashing tools:
– KTAG.
– New Trasdata.
– New Genius.
– Kess.
– BitBox.
– VF 2 Flasher.
– Flex by Magic MotorSport.
– ECUF Flasher by Alex.
– PCM Flasher.
– Toyota Lexus ECU Flasher.
Notice: CUW to BIN Converter
HEXPROG Online CUW Converter: https://www.cuwconverter.ru/
[Image: 22120910525625315418066401.png]
godinhojr Offline
(12-09-2022, 09:24 PM)lfas Wrote: TOYOLEX 3 for DPF EGR DTC AdBlue IMMO IMV disable…, costs 150$
features:
– KTAG.
– New Trasdata.
– New Genius.
– Kess.
– BitBox.
– VF 2 Flasher.
– PCM Flasher.
1 pc or 150 with keygen?
nusa1979 Offline
The same program is sold for 40$ on other forums
