Latest news: ---- DELPHI 2021.10B + AUTOCOM 2021.11 FILES MEGA ---- DPDU Passthru Driver TOOL ---- ODIS-S 26.0.1 + ODIS-E 22.0.0 FULL ---- TOYOTA DENSO ECU IMMO DTC FILES MEGA ---- Xentry SDconnect Toolkit Fix 09.2026 ---- XENTRY RELEASE 4 - 09.2026 FILES ---- SRS AIRBAG CRASH KILLER + KEYGEN FULL ---- Kraken Auto Database ECU Tool ---- Autotuner File Converter Tool ---- SDT-II 2.43.0.126 Files MEGA ---- MUT-III PassThru 26061-00 Files MEGA ---- BMW ISTA GUI 2.1.0 NEW UPDATE ---- Scania DEC2 Engines Control System Software Files ---- BMW ISTA 4.57.21 Polish Language ---- BMW PSdZData 4.61.30 Files FULL ---- FVDI Software Download Files MEGA ---- FTAG 1.1.0 Checksum Correction Tool MEGA ---- All BMW Maps In One Place Files Torrent ---- BMW Easy Connect 2 1.4 TOOL ---- FTAG 1.0.1 Checksum Tool + Keygen FULL ---- VAG Dash Editor Tool FULL ---- JLR SDD 167 VM FILES MEGA ---- HU45 JP ECE FILES MEGA ---- ECU Forge - Converter KP to XDF ---- Error p0012 on Peugeot 206 1.4 16v (kfu) ---- ebs 3 wabco checksum correction ---- ODIS 26 + Patch ---- Unlock ECU Seed key Calculator TOOL ---- ZOOMLION ZCC550V MANUAL NEED HELP ---- XENTRY XDOS XPT 09.2026 FILES MEGA ----
Cummins InPower Pro 14.5 (installation files)
Cummins
InPower provides the following functions for monitored equipment:
•    Direct connection capability from a personal computer to PowerCommand genset controls, transfer controls, and system controls;
•    Allows the monitored equipment to send alarm information to a connected computer.
•    Configurable for units of measurement, and level of user access (read only, read/change values, administrator).
•    Adjustment of nearly every adjustment parameter within the connected control system, including parameters such as voltage and frequency levels, gains, protection set-points and other values.
•    Convenient programming of configurable inputs in the controllers.
•    Viewing of equipment history, fault codes, and data associated with fault codes.
•    Generates reports of monitored data
•    Allows released firmware upgrades on Power Command genset controls.
•    Plot critical parameters in a strip chart format, and export data to 3rd party software tools for manipulation and viewing.
•    Simulate fault conditions in genset controls in compliance to NFPA 110 requirements to demonstrate functionality of the controller and monitoring equipment in a facility.
[Image: bce9ef7d112c8bb3cd0026aa8a8898eb.png]
The link is working again
Thanks given by: Sidneysrc , Sidneysrc
(09-13-2023, 08:19 PM)Sidneysrc Wrote:
(12-30-2022, 07:43 PM)Aleksey-MS Wrote: O link está funcionando novamente
por favor me envie a senha
The link was updated
