Latest news: ---- DPDU Passthru Driver TOOL ---- ODIS-S 26.0.1 + ODIS-E 22.0.0 FULL ---- TOYOTA DENSO ECU IMMO DTC FILES MEGA ---- Xentry SDconnect Toolkit Fix 09.2026 ---- XENTRY RELEASE 4 - 09.2026 FILES ---- SRS AIRBAG CRASH KILLER + KEYGEN FULL ---- Kraken Auto Database ECU Tool ---- Autotuner File Converter Tool ---- SDT-II 2.43.0.126 Files MEGA ---- MUT-III PassThru 26061-00 Files MEGA ---- BMW ISTA GUI 2.1.0 NEW UPDATE ---- Scania DEC2 Engines Control System Software Files ---- BMW ISTA 4.57.21 Polish Language ---- BMW PSdZData 4.61.30 Files FULL ---- FVDI Software Download Files MEGA ---- FTAG 1.1.0 Checksum Correction Tool MEGA ---- All BMW Maps In One Place Files Torrent ---- BMW Easy Connect 2 1.4 TOOL ---- FTAG 1.0.1 Checksum Tool + Keygen FULL ---- VAG Dash Editor Tool FULL ---- JLR SDD 167 VM FILES MEGA ---- HU45 JP ECE FILES MEGA ---- ECU Forge - Converter KP to XDF ---- Error p0012 on Peugeot 206 1.4 16v (kfu) ---- ebs 3 wabco checksum correction ---- ODIS 26 + Patch ---- Unlock ECU Seed key Calculator TOOL ---- ZOOMLION ZCC550V MANUAL NEED HELP ---- XENTRY XDOS XPT 09.2026 FILES MEGA ---- Allison DOC 2026 Official Commercial Diagnostic Software ----
GM GDS2 v2023.10 with Chevrolet, Opel, Vauxhall - Torrent, Mega
Chevrolet
Program for diagnosing GM vehicles using the J2534 adapter. The distribution of diagnostic packages is Chevrolet Europe (2010-2017), Opel / Vauxhall (2010-2020). For full operation, a J2534 adapter is required that supports CAN bus on 6-14, 3-11, 12-13 contacts of the OBD2 connector, as well as a single wire CAN bus on pin 1.
[Image: GM-GDS.jpg]
The link is working again
Thanks given by: Robertjax
serigle06 Offline
(07-11-2022, 09:01 PM)aleksey-ms Wrote: GM GDS2 v2021.04 with Chevrolet, Opel, Vauxhall - Torrent, Mega
[Image: GM-GDS.jpg]
PASS PLEASE¡
[Image: GM-GDS.jpg]
PASS PLEASE¡
Teppei1981 Offline
Opel
Please excuse me if I am off-topic, but you may have an example of this J2534 adapter that supports the CAN bus on the OBD2 connector contacts 6-14, 3-11, 12-13, as well as a single wire CAN bus on pin 1.
I’m learning from you.
(08-27-2022, 09:33 PM)Teppei1981 Wrote: Please excuse me if I am off-topic, but you may have an example of this J2534 adapter that supports the CAN bus on the OBD2 connector contacts 6-14, 3-11, 12-13, as well as a single wire CAN bus on pin 1.
I think for example Scanmatic 2 Pro should work.
Thanks given by: Teppei1981
Namacha2009 Offline
Pass?
(09-25-2022, 06:04 AM)Namacha2009 Wrote: Pass?
Added GM GDS2 - MDI2 Manager v9.1.1766.85 + Deliverables and Installs 2023
