Latest news: ---- I have an original Delphi diagnostic ---- John Deere Advistore 5.4.44 ag+cf 2025/07 ---- SIM3K543-E2 ECU Catalyst Off Calibration TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Engineering PET2 PCM FULL ---- XENTRY XUS DAS WIS EPC STARFINDER VEDIAMO MONACO 09.2026 ---- WinOLS File Unlocker Stage Extractor Tool ---- PROGRAM ECU TUNING SOLUTION 1.02 FREE FOR ALL ---- MAGIC TUNERS PACK + KEYGEN FULL ---- PROGRAM ECU TUNING SOLUTION 1.01 FREE FOR ALL ---- PETKA 8.9 FILES + VIN SEARCH FULL ---- MTX DTC REMOVER 1.8.5.0 + KEYGEN FULL ---- AlfaOBD PC Version PRO + Lic Generator ---- VCDS 26.9.0 LAST VERSION + LOADER FULL ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ----
vocom II mini not detected by techtool
translucian Offline
Hello,
I bought a new original vocom 2 mini with wifi only.
I tried to pair it successfully with vocom II monitor and it worked,
I use only acces point mode and set mapping in different modes for it to be availible.
The issue is the unit does not pass communication to vehicle j...protocol and techtool sais that there is no vocom II tough connected.
Has anybody figured this out ?
Thanks given by: Smer4dsn , Rayzen , bungee83 , DANI1980
ied99 Offline
(11-11-2021, 06:51 PM)translucian Wrote: Hello,
DID YOU FIX TAHT I HAVE THE SAME PROBELM PLASE!
ADS69 Offline
Hi,
Your problem is most likely not with the Vocom itself, but rather with the configuration or compatibility.
Here are the most probable causes:
PTT version too old → the Vocom II Mini is only recognized from version 2.8 onwards. If you're on 2.7 or earlier, it will never be detected.
Wi-Fi mode → in access point mode, the software doesn't recognize it properly. Put it in Client mode (so it connects to the same Wi-Fi network as your PC).
Drivers → check in Device Manager that you have "Vocom II Mini Ethernet Adapter". If not, reinstall the drivers via the Config Tool.
Vehicle protocol → the Mini doesn't always support J1708 (only CAN/J1939). If your truck is a bit older, that might be the issue.
Try this first, but in my opinion it's either the PTT version or the Wi-Fi mode.
Thanks given by: MizteriouzA , motya , ZAGO , byarifo , lordhaos00 , Frankywaf
