Latest news: ---- BMW Easy Connect 2 1.4 TOOL ---- FTAG 1.0.1 Checksum Tool + Keygen FULL ---- VAG Dash Editor Tool FULL ---- JLR SDD 167 VM FILES MEGA ---- HU45 JP ECE FILES MEGA ---- ECU Forge - Converter KP to XDF ---- Error p0012 on Peugeot 206 1.4 16v (kfu) ---- ebs 3 wabco checksum correction ---- ODIS 26 + Patch ---- Unlock ECU Seed key Calculator TOOL ---- ZOOMLION ZCC550V MANUAL NEED HELP ---- XENTRY XDOS XPT 09.2026 FILES MEGA ---- Allison DOC 2026 Official Commercial Diagnostic Software ---- Xdos SDconnect C4 To ConfigAssist Fix ---- HHTWin Win64 v1.9 Files FULL ---- Thermo King CanDiag 1.21 Software Full ---- Scania SDP3 v2.71.3.2 File Mega ---- WABCO SOFTWARE COLLECTION FILES FULL ---- Toyota GTSplus v2026.02.002 EU Files Mega ---- TMS374 DECODER IMMO OFF TOOL ---- BMW Easy Connect v1.3 New TOOL ---- iDecoder 4.5 VIN PIN DPF DTC TVA IMMO OFF FULL ---- Peugeot PSA Wiring Diagrams Files Full ---- PSA Interface Checker New TOOL ---- SUZUKI SDT-II 2.39.0.15 FILES MEGA ---- BMW ETK Price 09.2026 ---- Wabco Software Collection Full ---- Scania Xcom 2.54 + Plugin Full ---- John Deere Payload Files Complete Mega ---- MUT III SEPE FILES MEGA ----
MT-Pro 4.1 - Automotive Motortester Oscilloscope (in EN RU ES PT)
MF
The price does not include delivery, as Depends on the region and the weight of the kit.
The program has next language: English, Russian, Spanish, Portuguese.
MT-Pro 4.1 Maximum kit - $595
  1. Measuring unit, patch cord, power cable, hook, CD. For the diagnosis of electronic and electrical systems of a car
  2. BB capacitive sensor. For the diagnosis of classic ignition systems with a mechanical distributor or a common central explosive wire
  3. The sensor of the first cylinder. To synchronize the first cylinder and mark the parade of cylinders
  4. Vacuum sensor. To control the timing of the timing, diagnose the piston group, check the uniformity of the cylinders, search for misfire 2 pcs
  5. The probe is measuring. Universal measuring probe ending with a flexible needle 3 pcs
  6. Set of explosive capacitive sensors DIS-6. For the diagnosis of bipolar ignition systems (DIS) of 2, 4 and 6 cylinder engines
  7. Temporarily does not come with the kit! Pressure sensor (DD) PS100 at 100 bar + pressure sensor extension
  8. Test lead ending in two crocodile clips
  9. Measuring probe ending with two needle-needle outputs
  10. Inductive sensor Lx1. For first cylinder synchronization in individual ignition systems
  11. Inductive sensor Lx6. For the diagnosis of an individual ignition system of 6 cylinder engines
  12. Temporarily does not come with the kit! Vibration Sensor (DV). For monitoring the condition of nozzles in gasoline and diesel engines, high-pressure fuel equipment, determining the moment and duration of injection, it can also be used as a sensor for the strobe of a diesel engine
  13. Spark Polarity Detector (DP). To quickly determine the spark polarity of bipolar ignition systems (DIS) and to verify the correct connection of coils in distributor systems
  14. Temporarily does not come with the kit! Photosensor (PD). For the test, the efficiency of the cylinders in cases where the engine does not have a standard crankshaft position sensor or access to it is very difficult
  15. Six-needle measuring probe
  16. Hantek CC-650. For the diagnosis of battery, starter, alternator.
[Image: MT-Pro-Full.jpg]
MT-Pro 4.1 Start kit - $325
  1. Measuring unit, patch cord, power cable, hook. For the diagnosis of electronic and electrical systems of a car
  4. Vacuum sensor. To control the timing of the timing, diagnose the piston group, check the uniformity of the cylinders, search for misfires
  5. The probe is measuring. Universal measuring probe ending with a flexible needle.
If you need it and write to me for details.
A new high voltage capacitive sensor Cx1 (timing sensor) has been developed
[Image: MT-Pro-CX-1.jpg][Image: MT-Pro-CX-1-.jpg]
[Image: MT-Pro-CX-1--.jpg]
Added next languages for this program - English, Russian, Spanish, Portuguese. And upload the link on them.
We are expecting a new batch of this oscilloscope in 10-14 days.
The price will be higher than before, but not much higher.
The batch is limited and since it has been out of stock for a long time, we will sell it quickly.
If you want to buy MT-Pro oscilloscope, you can leave a prepayment to reserve it.
Prices and kit lineup has been updated.
Motor tester in stock. Shipment starts in 14 days.
