Latest news: ---- Easy Kill v2.0 Start-Stop Off Tool ---- iDecoder 4.5 Ultimate Automotive ECU Immo Solution ---- ECU Repair Guide 2022 TOOL ---- Challenger TerraGator 3244 Service manual ---- JPRO 2026 v1.1 WITH ACTIVATION FULL ---- BMW ISTA Voltage Terminal Warning Disabler TOOL ---- PCR2.1 UNLOCKER TOOL FULL ---- IMMO Universal Decoding 3.5 Delete IMMO OFF ECU ---- BMW Easy Connect 2 v1.6 TOOL ---- Cmp Hex Tool Full ---- DTS Monaco 9.02 + Keygen + Patch FULL ---- Mercedes Gear Tool Full ---- Scania Xcom 2.54 + Plugin Full ---- GPEC2 GPEC2A FIRMWARES + KEYGEN ---- BMW ISTA-P 3.75.0.400 Modified ICOM A1 A2 Support ---- Complete Automotive Workshop Software Collection Full Version ---- Automatic Transmission Repair Manuals Rebuild Parts ---- BMW ISPI ISTA Launcher Offline Version MEGA ---- Bosch ESI [tronic] 2014 DVD1+DVD2+DVD3 Diagnostic Software ---- L-Suite Checksum Tool 1.03 Full Pack With KSuite DLLs ---- Actia Multidiag J2534 PassThru Support Full ---- hello from norway ---- Cummins Insite 9.3.0.22 Files Mega ---- SWFinder 6.1.8 File MEGA ---- ISTA iLean Voltage 4.61.40 No License No ISPI Admin Client ---- BMW ETK Price 10.2026 ---- Multi Editor Honda Tool Full ---- ECU Circuit Diagram Bosch Schematic ---- BMW FSC GENERATOR MG1 MD1 MSD DME TOOL ---- Wabco Calculator PIN1-PIN2 Activator Keygen ----
VmWare AutoData 3.45 Last FREE FOR ALL
AutoData 4.35 Last in VMWare Win7Pro 32bit FREE FOR ALL
    Size 19GB total, 7GB archive (WinRAR)  No passwords needed!
AutoData 4.35 is a program for car services, includes information on auto repair, repair interval with a list of works, diagnostic data, lubricants and their volumes, electrical circuits, working diagrams.
Including data: Conditioners.  ABS. Belts, chains and timing gears. Engine management systems, component testing. Engine management. Control unit connectors. Key programming. Service indicators.
In general, this is exactly the program that any service station needs!
A virtual machine with a preinstalled program is a convenient tool for solving a necessary task.
The program is already installed and configured, no additional time and knowledge is required for tuning and optimization, you just turn on the Virtual Machine and work!
Best regards, SerJ-R !
Main windows:
[Image: 1-Main-Windows.png]
Program start and version:
[Image: 2-Program-Start.jpg]
Program work:
[Image: 3-Car-select.jpg]
[Image: 4-Data-Category-Choose.jpg]
[Image: 5-Tech-Data.jpg]
[Image: 6-Repair-Times.jpg]
[Image: 7-Wheel-Aligment.jpg]
[Image: 8-Timing-Belt.jpg]
[Image: 9-Service-Illustrations.jpg]
[Image: 10-Service-Shedules.jpg]
If you use my products, "Thanks" and "Reputation" are the best rewards!
dodge1977 Offline
It is not working, it says E0209 Sentinel key not found.
Thanks given by: bookini
(10-04-2021, 01:30 PM)dodge1977 Wrote: It is not working, it says E0209 Sentinel key not found.
Thanks!  I will check it on another PC and fix, if need.
a86anton Offline
Hi all.
Hi all.
I found the solution to the sentinel problem.
You must follow the steps to install the "SentinelDriver" program, and when it asks you if you can modify / repair / uninstall, choose the repair mode.
After restart it will work.
Thanks!
dodge1977 Offline
Hi all.
Hi all.
Thanks!
Where can we found " progit
Where can we found the "SentinelDriver" program ?
Yes I see onto many people have a problem with this VM.
I will correct this and re-upload VM again in some days.
Best regards
(10-10-2021, 07:13 AM)batya303 Wrote: Nagyon köszönöm és várom, de azt is tisztázni kell, hogy intel vagy amd host környezetben készült -e, mivel az illesztőprogram módosításai zavaróak lehetnek !!
My PC is Intel SkyLake I9  based, not AMD.
Virtual Machine is updated! Please try to use onto your PC! Best regards, Sergey!
dodge1977 Offline
Now it is good working, very good job.
Thank you.
Thanks given by: Prodrive , bookini , bookini
FILAT_TR Offline
Hello. Can you pls update link?
