Latest news: ---- BMW Easy Connect 2 1.4 TOOL ---- FTAG 1.0.1 Checksum Tool + Keygen FULL ---- VAG Dash Editor Tool FULL ---- JLR SDD 167 VM FILES MEGA ---- HU45 JP ECE FILES MEGA ---- ECU Forge - Converter KP to XDF ---- Error p0012 on Peugeot 206 1.4 16v (kfu) ---- ebs 3 wabco checksum correction ---- ODIS 26 + Patch ---- Unlock ECU Seed key Calculator TOOL ---- ZOOMLION ZCC550V MANUAL NEED HELP ---- XENTRY XDOS XPT 09.2026 FILES MEGA ---- Allison DOC 2026 Official Commercial Diagnostic Software ---- Xdos SDconnect C4 To ConfigAssist Fix ---- HHTWin Win64 v1.9 Files FULL ---- Thermo King CanDiag 1.21 Software Full ---- Scania SDP3 v2.71.3.2 File Mega ---- WABCO SOFTWARE COLLECTION FILES FULL ---- Toyota GTSplus v2026.02.002 EU Files Mega ---- TMS374 DECODER IMMO OFF TOOL ---- BMW Easy Connect v1.3 New TOOL ---- iDecoder 4.5 VIN PIN DPF DTC TVA IMMO OFF FULL ---- Peugeot PSA Wiring Diagrams Files Full ---- PSA Interface Checker New TOOL ---- SUZUKI SDT-II 2.39.0.15 FILES MEGA ---- BMW ETK Price 09.2026 ---- Wabco Software Collection Full ---- Scania Xcom 2.54 + Plugin Full ---- John Deere Payload Files Complete Mega ---- MUT III SEPE FILES MEGA ----
Doc90 Offline
Peugeot
Hello everyone, my name is Davide.
I would like to share a problem that has been troubling me for several days now, and I would be grateful for any advice from those of you who might have encountered this issue.
Basically, after I replaced the cylinder head gasket, I get the P0012 error in diagnostics. This error refers to a delay in the opening of the intake valves. It is related to the variable valve timing (VVT) on the intake camshaft.
I should note that I have tried various steps: I replaced the solenoid and manually tested its operation; I replaced the camshaft position sensor and the crankshaft position sensor; I also replaced the variable valve timing actuator. I have checked multiple times, and the timing is correct. The variable valve timing actuator is correctly positioned on the camshaft, thanks to the alignment pin, so I would also exclude any incorrect assembly.
I also changed the oil and the filter.
The car starts immediately, but it struggles to move from a standstill; I have to keep the RPMs up, otherwise it stalls. During driving, it jerks and hesitates. The engine warning light doesn’t come on the dashboard, but the error P0012 appears during diagnostics.
I haven’t yet checked the oil pump pressure, even though I don’t think the problem is the pump, since the issue appeared after the head work.
Could it be a faulty reading? Perhaps a loose contact on the wiring to the camshaft sensor? I should verify continuity from the ECU to the sensor connector. I’m not sure.
In sharing this rather strange case with you all, I hope that someone has encountered this problem before, and I thank anyone who can offer advice on this matter.
7 Guest(s)
