Latest news: ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ---- Volvo Tech Tool PTT 1.12 + Keygen Full ---- xDecoder 14.0 Launcher Package Fix ---- HP Tuners 5.1.1.198 + VCM Keygen FULL ---- SM3 Scanmatik Alpha4 PCMflash ---- JLR SDD ENGINEERING CALCULATOR TOOL ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ----
Xentry Full Fix 4.9.8 Soft Easiest Installation Activation
XENTRY Special Functions Keygen + FDOK Calculator
DAS Standalone & DAS Simulation, And fix Error (18)
DAS Special Functions & password
Prototype in DAS. Adding 166, 197, 204, 207 and 212 DAS Standalone (have to install DAS Standalone).
Offline flash in DAS Standalone
HHTWin
Ignition Enabler (if you us PassThru version).
SEED Calculator UnlockECU
Vediamo 4.02.02 or Vediamo 5.01.01. Install and easy activation
SW Finder v5.2 installer fixed and updated
VGSNAG2 Manager
DTS Monaco 8.16, install, Fix Blue Screen and configs for VCX SE
Install Openport 2.0 driver from official website and china driver.
Instal Scanmatik driver from official website.
Install VX Manager
Diagnose DoIP models with ENET cable for XDOS (working only with XDOS 09/21 to 12.24)
Added one more seed calculator SeedCalc
Added 7G SCN
Added launch WIS 2021 from Xentry OpenShell (till 09.2024).
Secure boot in Bios must be DISABLED
Antivirus must either be DISABLED or you must set appropriate Antivirus exceptions to ensure that it does not interfere with the files
Instructions for Xentry activation
You have to install Xentry, restart PC.
Install Full Fix 4.9.8
Activate Xentry in Config Assist (shortcut for Xentry Advanced Keygen on desktop)
Start Xentry from desktop icon. When starting Xentry and the program asks for offline login, depending on your Xentry version, you can enter:
Login: z
Password: z
Login: 11
Password: 22
Or leave the fields blank if Xentry is not so new.
nordreprog Offline
thanks for job can you send me password please
(09-08-2026, 03:27 PM)nordreprog Wrote: thanks for job can you send me password please
Pass - automotiveforum.net
