Latest news: ---- WINOLS TO BIN TOOL NEW ---- Toyota EPC 09.2023 Files Mega ---- Ford Wiring Diagram All Cars ---- K-Tag 2.25 K-Suite ISO File Mega ---- SWFinder 5.2 With Fix Full ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- BMW ISTA-Patcher GUI 1.7.1 New Update ---- CHANGE HOUR USE IN CATERPILLAR? ---- cnh 9.7 or newer keyegen ---- BMW HUTOOLS 2.6 NBT EVO CIC NEW UPDATE ---- Big Software Immo Off Collection + Keygen Full ---- CNH EST 9.7 + KEYGEN AND INSTRUCTION ---- Vediamo 04.02.02 + Keygen Full ---- CUMMINS INSITE FIS FILES MEGA ---- SCANIA MULTI EPC SPARE PARTS CATALOG 2505 MEGA ---- BavCalc 1.2.5.13 Radio Immo Dashboard + Keygen ---- BMW FSC Validator 1.1 New Update ---- BMW ALPINA ETK EPC ---- request SQLiteDBs (Spanish - ES) BMW ---- BMW FSC Validator TOOL ---- BMW ISTA 4.60.3x I-LEVEL OVERVIEW ---- GM PCM Programming GM Tech2 + TIS2000 FULL ---- BMW MGD1 FSC GENERATOR FULL ---- BMW ISTA 4.60.30 Standalone Full ---- Chrysler J2534 V16.01-16 Install Files Full ---- VCDS 25.6.0 Installer + Loader 08.025.12 FULL ---- BMW ISTA-P Loaders Files FULL ---- WABCO TEBS-E 7.20 FILES MEGA ---- PACCAR ESA 5.7 SW Flash Files MEGA ---- BMW MG1 FSC SOLUTION TOOL ----
Jaguar Land Rover JLR SDD 166 2025 - Torrent File
Land Rover
Jaguar Land Rover JLR SDD 166  - Torrent File
Questions about the password, write in a personal.
Asking for a password in a topic will be ignore.
[Image: fba0b2c28849abed5fa4fe936e0be97b.png]
Year / Release date: 02.2025
Version: 166
System requirements: windows 7 - 11 x86 x64
Interface language: Multilingual
Description:  SDD supports 2007-2016 JLR models.
Additional information: If you want me to do the installation, setup and activation personally, Write me a private message.
Activation instruction with a complex activator:
1) Install vcredist2005_x86
2) Install SDD_166.00.exe
3) For Windows x64, run cmd (Command Prompt as administrator) and type: mklink /D "C:\Program Files\ JLR" "C:\Program Files (x86)\JLR"
4) Without closing the command line, point to the patch.bat file and run it
5) Edit C:\Program Files\JLR\SDD\SDD\app.properties and C:\Program Files\JLR\IDS\SDD\ app.properties and add the following lines to the end of the file:
      sdd.authentication.topix.address = http: //asdaswq.re
      sdd.windows10.enabled = true
      sdd.ie11.enabled = true
6) Run jlr sdd from the desktop
7) Restart Edge in Internet Explorer mode
8) The window shows that the topic is not available. Click "Continue"
9) paste any username and continue
    Need it? Push buttons Rate (Reputation) and Thanks, PM (write in Private Messages) for pass.
voldemaras Offline
Version: 166
  [Image: _9c86ef4dd5b3fd8bcf6af7af13aca1cb.png?md...1739545200]
Rep (Reputation) + Thanks
send password
arbenit Offline
Version: 166
  [Image: _9c86ef4dd5b3fd8bcf6af7af13aca1cb.png?md...1739718000]
Land Rover
